20 Most Recent Connex CX-3400hp AM/FM 10 Meter Amateur Mobile Transceiver Questions & Answers
Converting 10 meter to 11 meter on Connex CX-3400HP CB RADIO
Turn the mode switch to the setting you want and leave it there .
10/3/2018 8:02:19 PM • Connex CX-3400hp... • Answered on Oct 03, 2018
Connex 3400 hp makes static noise when I hit bumps in road.
don't hit any more bumps. The problem could be in several areas. I'm going to say that you may have a loose capacitor inside If I had the radio here I could fix it but because the problem may be so spread it could be a lot of things Are you a truck driver? If you are take it to a CB shop at one of the many truck stops and see if they can fix it for you .
1/27/2016 5:51:49 PM • Connex CX-3400hp... • Answered on Jan 27, 2016
I have a Connex 3400 Hp and it stopped receiving all of a sudden while driving down the road and the needle on my meter is dead on 0. I've doubled check to make sure all my knobs and switches we're in
check for a fuse bulb for the RX section i would have a radio engineer look at it as you smell stuff its also not a good idea to drive around with known faulty electronics in your car its a bad problem just waiting too blow up in your face... so.. dont leave electrical issue in cars your family depends on
11/23/2014 2:01:52 AM • Connex CX-3400hp... • Answered on Nov 23, 2014
Fix my connex 3400 hb sideband button
Hi there, if you are talking about the Connex CX 3400 HP there is no sideband or SSB on this radio. It is only AM and FM 10 meter Ham radio. Many people do modify these radios to include the 11 meter frequencies which is the CB band. Maybe knowing the actual bands and their frequencies will help some too this radio does have 6 different bands ranging from (Band A. 28.015 thru 28.455) (Band B. 28.145 thru 28.585) (Band C. 28.115 thru 28.555) (Band D. 28.085 thru 28.525) (Band E. 28.055 thru 28.495) (Band F. 28.025 thru 28.465.) I hope this will help you. Bob
12/9/2012 12:34:59 AM • Connex CX-3400hp... • Answered on Dec 09, 2012
0answers
Swr will not go under 2.5 even with antenna adjusted up and down
if your swr is higher on 1 then on 40 then your antenna is electrically short and you have to lenghten the antenna.If it is higher on 40 then on 1 then it is long and you have to shorten it. If you have to make it longer then you may have to add a quick disconnect or a coiled spring to make it longer. To make it shorter all you have to do is trim a 1/4 in at a time off the antenna whip but you must keep checking the match until it gets down below 1.5 .
10/3/2018 8:00:49 PM • Connex Radio... • Answered on Oct 03, 2018
My connex 3300hp radio randomly transmits and gets stuck without pressing mic button. It in sticks if you press mic button.
Have you tried keying it without the coax attached ? Take the mic apart and give it a squirt of electrical parts cleaner .Try using a different mic also.
10/3/2018 7:50:40 PM • Connex Radio... • Answered on Oct 03, 2018
Converting connex 4400 turbo to a cb
If you disable any part of the radio that does not pertain to CB then you could actually do damage to the radio. the best thing to do is leave it on the CB band and don't touch it.
10/3/2018 7:47:39 PM • Connex Radio... • Answered on Oct 03, 2018
When turn radio on channel indicator searches but will not stop search 3400 connex 3400
the radio is searching for a strong incoming signal and until it gets one it will search for one. Try turning off the scan button .
10/3/2018 7:44:35 PM • Connex Radio... • Answered on Oct 03, 2018
I stopped into a Radio shop and ask them for a power cord for my connex 4600 and he asked me what kind of truck I’m putting this radio in I told him a freightliner he said the connex 4600 Is the wrong radio for this this truck he said discharge don’t have a good ground I never heard that before
many trucks have a ground wire in the harness as the cabins are fibre glass or not grounded around the cabin mounts If the radio grounds out through the frame , then there would be no ground for the radio or the aerial wire to fit this particular may require such a wire in the harness for the radio which it probably doesn't have As you have been alerted to a problem, it would be advisable to talk with professional radio fitters who work on trucks to get the correct advice before starting on the job it could save a lot of frustration
11/23/2017 1:16:41 AM • Connex Radio... • Answered on Nov 23, 2017
Need a faceplate or faceplace sticker for a connex 4300x400wsm 10 meter cb radio. Any help at all would be greatly appreciated
Sorry we do not sell parts nor have the ability to locate them for you.
6/8/2017 6:29:00 PM • Connex Radio... • Answered on Jun 08, 2017
Connex CX-3400hp AM/FM 10 Meter Amateur Mobile Transceiver Logo
9 questions posted
Top Connex Radio Communications Experts
Damon Nesselrodt
Damon Nesselrodt
Tom Chichester
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Connex Radio Communications
Most Popular Question
connex 3400 hp makes static noise when
  • Radio Communications
