20 Most Recent Connex Cb Faceplate Sticker-fits 4300-300 Questions & Answers
turn rf gain up and the mic gain down until it stops squealing.
Connex Cb... | Answered on Sep 30, 2012
if your swr is higher on 1 then on 40 then your antenna is electrically short and you have to lenghten the antenna.If it is higher on 40 then on 1 then it is long and you have to shorten it. If you have to make it longer then you may have to add a quick disconnect or a coiled spring to make it longer. To make it shorter all you have to do is trim a 1/4 in at a time off the antenna whip but you must keep checking the match until it gets down below 1.5 .
Connex Radio... | Answered on Oct 03, 2018
Have you tried keying it without the coax attached ? Take the mic apart and give it a squirt of electrical parts cleaner .Try using a different mic also.
If you disable any part of the radio that does not pertain to CB then you could actually do damage to the radio. the best thing to do is leave it on the CB band and don't touch it.
the radio is searching for a strong incoming signal and until it gets one it will search for one. Try turning off the scan button .
many trucks have a ground wire in the harness as the cabins are fibre glass or not grounded around the cabin mounts If the radio grounds out through the frame , then there would be no ground for the radio or the aerial wire
to fit this particular may require such a wire in the harness for the radio which it probably doesn't have
As you have been alerted to a problem, it would be advisable to talk with professional radio fitters who work on trucks to get the correct advice before starting on the job
it could save a lot of frustration
Connex Radio... | Answered on Nov 23, 2017
If you ground the audio wire, you will have no noise or mic function at all. The mic hot wire and the shield should be enough to avoid hum.
Connex Radio... | Answered on Jan 22, 2017
Connex Cb Faceplate Sticker-fits 4300-300 Logo
1 questions posted
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Connex Radio Communications
Most Popular Question
connex 4300 300 squeals in talk back
  • Radio Communications
