20 Most Recent
Galaxy Radios DX 959 SSB CB Radio Questions & Answers
Swr light come on when i key it up
you must check your radio for low SWR.get it down below 2.1 and you should be ok.if you already have a low SWR then you may want to take it to a tech and let them fine tune it.
Galaxy dx 959not getting out far
MAKE SURE ALL CONTROLS ARE SET RIGHT MODULATION FULLY TO RIGHT CLOCKWISE, R-F GAIN FULLY RIGHT CLOCKWISE. TRY TO GET YOUR MATCH A LITTLE BETTER
GET YOUR BLOWN UP RADIO BACK ONLINE.
When you cant get your radio turned on. All it does is blow the fuse imeadiatlly hooking it to power. Most likely it is the (reverse polarity diode). The quick fix is to locate your diode? This diode usually is back behind a coil wound transformer on your board inside the radio and in the general area of where the possitive ans negative plug wires solder to the board! Usually it is black with a silver band around one end. If you clip it on one end or remove it this will restore your radios power. CAUTION:: When doing this ALWAYS use a dual fuse power cord . This will prevent this from happening again by blowing the fuse first. Doing this procedure will remove your thermal protection to the radio thus making it wide open to being fried for good if it ever gets hooked up backwards again. This is my reasoning for the dual fused power cord. Good luck!
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
3 days ago
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
