20 Most Recent
Dual Uv-5r Baofeng Band Uhf/vhf Radio Usb Program Cable Uv5r Questions & Answers
When programing with computer radio will not scan
Recommend using a program called 'Chirp' (free internet download) to program your radio. Ensure the fields are populated correctly.
Upload the file, let the radio program, and then turn radio off and remove the cable. Try the scan function once you turn the radio back on.
These types of radios are sensitive to programming errors.
Baofeng uv-5r will not transmit
Sounds like you have the transmit lockout set. this radio is a bit of a pain to program, but is well worth the effort. your best bet is save your settings (backup) and do a full factory reset, and start over, making sure you did not lock out the transmit on any channel or VFO...
My aircel sim has locked and my no is 9551177091
If it is your sim that is locked, then what you need is your PUK code (Personal Unblocking Key).
It is found inside the sim cards pack. It is the 8 digit code that is on top of the sim card carrier. In some cases it used to be more than 8 digits or lesser.
When you purchased the sim it came in a pack consisting of the user manual, the sim card carrier, then the casing.
On the sim card carrier where you broke out the sim card from, you will see your number, the sim pin, then you will see a 8 digit code that is the puk code.
Enter it and it will prompt you for a new pin, enter the new pin and confirm it, then your phone will be unblocked.
Hope this Helps.
Take care and good luck
12/15/2010 11:19:33 AM •
Dual Radio...
Answered
on Dec 15, 2010
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
