20 Most Recent
BellSouth Auto multi-channels 2-way radio walkie talkie t-388 2pcs Questions & Answers
Where can I get a manual?
do a web search include the make and model of the units and add various words such as instructions...manua....guide etc
several results will be thrown up, you will have to trawl
through them
I need a manual
http://www.upzone.com/downloads/summary/7-manual/1254-the-manual-of-walkie-talkie-atomatic-battery-save-walkie-talkie-88006651.html
Is the two way radio easily fixed, suspect mic, or is it garbage?
If you can do minor soldering, you may be able to fix the radio. They have no parts available, so they are considered "junk" when they break. But if you do the following, you may be able to repair it: open radio, unscrew the housing and pull it apart. Take the circuit board and look for corrosion, it often looks greenish or white. If the radio has a lot, there is water damage. You may still be able to fix it. You've gone this far! Use a Q Tip dipped in rubbing alcohol and remove as much corrosion as you can. Let it dry. Take your soldering gun and lightly resolder each spot on the circuit board. Touch the tip, as soon as the solder turns liquid, remove it! I have fixedhundreds of radios and cell phones by doing this. But it may not work. It just takes your labor! Good luck!
