20 Most Recent Vizio M261VP 26-Inch 1080p LED LCD HDTV Refurbished Questions & Answers
hi there! John
Sometimes it is the cable, has to make sure is well pressed, second, cauld be a bad TV power assemble inside. RMS, required. third, some models has two power buttons one is below or side unit, and the other is on the remote , or front /side panel of the TV.
Vizio M261VP... | Answered on Oct 02, 2013
Sometimes uses 305 codes, or 340, but from the manuals, get the generic codes.
ASK GOOGLE .COM
Vizio Televison... | Answered 22 hours ago
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Vizio Televison... | Answered on Jan 16, 2020
Have you done the two year technicians course?
Here is a question that we see often.
Question:
I've replaced everything in my television because it previously had a black screen with no lighting. Now it doesn't turn on at all and all I have is audio. What could be the cause ?
So your television stops working properly and you think it must be easy to fix, because you can buy boards on eBay, and you can watch YouTube videos. So you make a decision, you buy a board and you fit it, but the television still doesn't work! This is a classic case of the 'let's try replacing this' method of television repair and illustrates why it is a bad idea. It doesn't work for a number of reasons. To correctly diagnose issues, you need to know every board, what is does and every component on the board. You need to know which part has failed, replace the component, or replace the board. The parts you purchased off eBay were probably out of scrapped sets and not tested. The part your put in was dead when you put it in, so you just moved on to another guess at what might be the cause and replace a board that is fine. And so it goes on, you change all the boards and it still doesn't work. Did you notice the large print that says 'No Refunds, NO Returns'. This is to stop you sending your old one back and saying it didn't work, but the unscrupulous use it as an excuse to get money for selling items that may not work! The course to be a television engineer is 2 years full time education, take it to someone that knows how to diagnose and fix. It is by far the cheapest option. The part that failed might be a 20 cents fuse diode hard soldered to a board. They will charge you $2 parts and an hours labour.
Vizio Televison... | Answered on Jan 14, 2020
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Vizio Televison... | Answered on Jan 11, 2020
Get a strong flashlight, turn on the tv shine the flashlight into the screen and see if you can see a picture.
It is possible that the back light board has stopped working.
Info for fixing it can be found on Youtube.
Regards
Geoff
Vizio Televison... | Answered on Jan 08, 2020
Back-light problem one of the leds has died.
When this happens all the led lights in the back-light go out.
Regards
Geoff
Vizio M261VP 26-Inch 1080p LED LCD HDTV Refurbished Logo
4 questions posted
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
anyone know program rca system link
  • Televison & Video
