20 Most Recent Altec Lansing Computer Speakers 2 Gcs100 Model Questions & Answers
Altec lansing Acs45 subwoofer sounds blown
Most probably output capacitor need replacement.
1/26/2024 11:42:20 AM • Altec Lansing... • Answered on Jan 26, 2024
7 WIRES , WHAT COLOR GOES TO WHICH PIN? 2 BLACK , 1 GREEN, ONE YELLOW, ONE WHITE, 2 ORANGE, ONE HEAVIER THAT THE OTHER
Hi Jerry What Model....? Using a mobile phone camera would have helped in this situation. Before taking things apart I'll be very surprised if someone has the same speaker system in bits somewhere An electronics guy would trace the wire back to it's source to decide what it's being used for. Good Luck Review Altec lansing BXR1220 Speakers 8 Altec Lansing Avs300 PC Speakers Sub
12/23/2023 2:19:36 PM • Altec Lansing... • Answered on Dec 23, 2023
Altec Lansing ATP3 speaker volume control repair.
The problem is usually getting into them. https://www.google.com/search?q=Altec+Lansing+ATP3+speaker+volume+control+repair different model
8/7/2023 11:40:23 PM • Altec Lansing... • Answered on Aug 07, 2023
Altec Lansing 221 7 pin subwoofer connector pinout
1121? Altec Lansing used to be good speakers, but not any more. https://www.google.com/search?q=Altec+Lansing+221+7+pin+subwoofer+connector+pinout ..
3/8/2023 5:55:12 PM • Altec Lansing... • Answered on Mar 08, 2023
Altec Lansing MX6021 Expressionist ULTRA 2.1
The "pluc pluc pluc" noise you're hearing from your Altec Lansing MX6021 Expressionist ULTRA 2.1 speakers could be a sign of a few different issues. Here are a few things you can try:
  1. Check the cables: Make sure all cables are connected properly and there are no loose connections. Try using a different cable to see if that solves the problem.
  2. Check the power supply: Ensure that the power supply is plugged in and working properly. Try using a different power outlet or power supply to see if that solves the problem.
  3. Check the volume: Make sure that the volume on your device is turned up and the speakers are not on mute.
  4. Try a different device: Connect the speakers to a different device to see if the issue is with your laptop or the speakers.
  5. Check for software updates: Visit the Altec Lansing website to see if there are any software updates or firmware updates available for your speakers.
If none of these solutions work, it may be time to consider contacting Altec Lansing customer support or a professional audio technician for further assistance.
2/26/2023 6:42:44 AM • Altec Lansing... • Answered on Feb 26, 2023
Where and how do I register Altec Lansing MZX300 Bluetooth over-ear headphones ???
-Read its owner manual. Good luck Mai
1/12/2023 12:27:25 AM • Altec Lansing... • Answered on Jan 12, 2023
2answers
Where can I buy altec lansing MX6021 CONTROLLER?
You can buy it online anywhere ebay/Amazon or according to me Aliexpress Homepage as biggest and cheapest worldwide suplier. Yust type the correct name into the searchbox and thats it
11/9/2022 11:33:52 AM • Altec Lansing... • Answered on Nov 09, 2022
MANUAL FOR CABLE WIRING OF ALTEC LANSING ACS31 MULTIMEDIA
Question moved from Cars and Trucks. There seems odd advice in here, but might make sense to you? https://www.ehow.co.uk/how_7777826_apart-audix-d6.html ACS33 manual https://www.manualslib.com/manual/365802/Altec-Lansing-Acs33.html No ACS31 except images https://www.google.com/search?q=ALTEC+LANSING+ACS31+manual ..
11/7/2022 12:16:41 AM • Altec Lansing... • Answered on Nov 07, 2022
2answers
Altec Lansing VS4121 sub-woofer stopped working, making a low hum, right and left fine. Possible fixes?
3 causes. generic. then real. 60Hz hum/.
  1. the PSU inside the SUB is bad, as in bad CAP's inside.
  2. input cables to it bad, shields broken (coax cables)
  3. bad source signals from what ever is connect to the sub.
in this case (no pun) the main case is the SUB and the PSU is inside the sub so sub bad. or test it with no L/R speakers yet , it still hums or is dead well the main unit is bad and needs service. OR the main has cable from PC to MAIN SUB case. IF this cable is bad, is first check.but that would make L or R fail too. a bad shield will not only effect the sub speaker, (hum) the PC end is only 3 conductors L and R and shield. some are sold double shielded, and are prime to own.. try a new 3.5mm phone patch cable, just in case his fixes it cheap. or the 2 cable ends to PC , phone plugs are lose or dipped in spilled drinks gunk. or PC is bad , ( try other sources , PC, phones, or mp3 /dvd players.) the PC bad would effect R or L too. IMO
8/7/2022 12:05:54 PM • Altec Lansing... • Answered on Aug 07, 2022
Blue ray code for altec lansing multimedia speaker
Question moved from Blue Computers to Altec Lansing. 'Blue RAY'? or 'Blue TOOTH'? Blue Ray is a digital video format. https://www.google.com/search?q=AL+4005 https://www.fixya.com/support/r26362721-pairing_bluetooth_devices ..
1/2/2022 8:15:43 PM • Altec Lansing... • Answered on Jan 02, 2022
Altec lansing acs41 computer speakers gateway 2000 speakers
hello can you repair my speakers if its possible 1997 Altec Lansing AC41 (Gateway 2000) please they is no power in my speaker if you want to contact with me in facebook https://www.facebook.com/profile.php?id=100025743036737
10/21/2021 9:34:36 PM • Altec Lansing... • Answered on Oct 21, 2021
I have Altec Lansing ada 885 I only have sub woofer can anyone tell me how to power on with out other speakers . Because I have no switch to turn on with no other speakers and also the name of he plug on the main subwoofer I don’t have those 3 what can I do
You do have a problem as the system is controlled by the right-hand speaker. I would suggest you somehow buy an ADA885 system where the main amp/subwoofer has blown, then you will have a complete system.
9/30/2021 5:39:50 PM • Altec Lansing... • Answered on Sep 30, 2021
2answers
I have a n altec Lansing speaker and it won't turn on
The truth is that inbound marketing is a technique commonly used to attract https://fixconnectionsbluetoothaudiodeviceswirelessdisplayswindows10.net more traffic to web pages and above all to be more successful on the Internet.
9/7/2021 6:26:30 PM • Altec Lansing... • Answered on Sep 07, 2021
Altec Lansing Computer Speakers 2 Gcs100 Model Logo
3 questions posted
Top Altec Lansing Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
 Grubhead
Grubhead
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Altec Lansing Audio Players & Recorders
Most Popular Question
altec lansing vs4121 sub woofer stopped
  • Audio Players & Recorders
