20 Most Recent
Allied Telesyn AT AR410 Router Questions & Answers
Forget the default password for ar410
ALLIED TELESYN
AT-8024(GB)
CONSOLE
n/a
admin
ALLIED TELESYN
AT-8024(GB)
HTTP
manager
admin
ALLIED TELESYN
AT ROUTER
HTTP
root
(none)
ALLIED TELESYN
ALAT8326GB
MULTI
manager
manager
ALLIED TELESYN
AT8016F
CONSOLE
manager
friend
ALLIED TELESYN
AT-AR130 (U) -10
HTTP
Manager
friendhope it helps
Router ar 410, wan port
Does the DSL router have a model number? Also for the public address, can you give me the first couple of digits. I just want to make sure it is truly a public IP address and not a class A or B private address because only an ISP can hand out public addresses.
If the IP address on eth0 is indeed private, I am guessing you have to get into the DSL router and set a static route to point to let it know about both of the the ar410 networks on each interface. Keep in mind it might not understand VLSM so when you static route in the DSL to the 192 network you will only need to specify it as 192.168.18.0 as class C default mask is 24.
Can you suggest a drop-in
There is no drop in replacement, the model is too old for that. You have 3 options
1 - source a functioning AT-8016F/SC online
or
2 - get the updated version - not entirely the same unit
http://www.pcconnectionexpress.com/1/1/56308-allied-telesyn-international-allied-telesyn-16-port-100fx-sc-l2-switch-w-2-expansion-slots-8516f-sc-10.html
or
3 - redo your entire network and switch to CAT cables and gigabit switches.
