20 Most Recent
Gaggenau 47 in. CK 594 Electric Cooktop Questions & Answers
Everytime we switch on the
the main problem should be an short circuit on the burner...there is nothing wrong with he switch cause other wise should stay on or off ..so as long it functions enough to burn the lights out..this means its ok ...so what you should replace it is the burner...just get it out from the screws and replace it ..cause it is something inside that is probably burned out ..and now it is making contact with the metal cover or something like this ....so pay attention on the power...do not touch a thing unless you get it off..
Im not sure about the replacement ...I mean where to find it ...but probably if they still make it there are pieces...if not ...just go to a repairing store and ask for one that will have the same specifications ..(resistance and power ) and if it will fit in the place will do ...even if it is from another model ..you just improvise something ...
Anyway ...there can be parts on line also ...Im not sure for the model ..just make a search for ...the part ..and name of teh device..
Replacement dual burner Gaggenau CK594
You have 2 line, 2 load, and if there is an indicator light, 1 for that and 1 ground. The other guy may be right about the 2 grounds, if not, the indicator light may have a connection for hooking it to another light in series. The tech cannot understand the schematic? get someone who can.
Where can I buy the stovetop burner gaskets?
www.repairclinic.com/Shop-For.../Gaggenau-Range-Stove-Oven-Parts Huge selection of Gaggenau Range/Stove/Oven parts in stock. Same day shipping. Open 7 days a week. ... Door hinge, top/bottom. OEM Part - Manufacturer # ...
7/11/2015 11:50:45 PM •
Gaggenau...
Answered
on Jul 11, 2015
Gaggenau 200 Series?
If it is similar to the VE260 model, this induction type of cook top is very old. 22 - 23 years if it came with the home when it was built.
I can only offer basic suggestions of which you already probably know.
These induction type cook tops rely on the pan or skillet to be magnetic like stainless steel. If the bottom of the pan has any buildup of residue, this will dramatically reduce the efficiency of the unit.
If the pans are immaculate, then the electronic elements that produce the magnetic induction to heat the coils must be weak. As old as the unit is, it is probably not feasible to have 3 of the elements repaired....
A new top can be purchased much cheaper. Consult Consumers Reports for unbiased product reviews for your best reviews. As a final suggestion, find someone who is qualified to use an electrical multimeter to read the current on both sides of the power receptacle to ensure that your voltage is 230V. A loose connection on the receptacle can cause the elements to have the same result.
Although I can imagine you have already done everything above, I just wanted to send you what I can offer.
1/2/2014 8:19:09 AM •
Gaggenau...
Answered
on Jan 02, 2014
