20 Most Recent Lexar Flash memory card - 32 GB - Class 4 - SDHC Questions & Answers
Memory card error
maybe it needs to be formatted,or sometimes there is a really small slider swith thingy that locks it so it cant be used or erased.
8/14/2012 3:59:18 AM • Lexar Flash... • Answered on Aug 14, 2012
How to disassemble mx5020 speaker?
Greetings, Please check the handbook of your device to see if there are diagrams highlighting the location of the screws for the speakers. Once located, you can start by using a screwdriver to remove those screws and open up the device. Otherwise, you might need to work with an electrician or possibly a pawnshop to help get the device open. Thank you.
3/27/2023 6:57:30 PM • Audio Players &... • Answered 3 days ago
2answers
I bought a PSWi-8M wireless
Unfortunately you need the transmitter. i would contact Polk and see if they sell this part separately or start scouring the internet. someone might have blown their sub but the transmitter would still work.
3/25/2023 8:46:19 PM • Audio Players &... • Answered on Mar 25, 2023
Motorola DCP-501 All-In-One Home Theater Receiver will not come on at all?
Check the power source and if you can get behind the switch, check for continuity. Make sure that the device is properly connected to a power source and that the outlet is functioning. You can test the outlet by plugging in another device. Check the power cable and make sure that the power cable is properly connected to the unit and the power source. Also, check for any damage or fraying on the cable. Check the power switch to ensure that the power switch is turned on. It is possible that it might have been turned off accidentally. Try resetting the device by disconnecting it from the power source, waiting for a few minutes, and then plugging it back in. If all those fail, you will need to take to an audio engineer.
3/25/2023 3:52:19 AM • Audio Players &... • Answered on Mar 25, 2023
Need manual for Micronta 63-712 world time
3/24/2023 6:59:55 PM • Audio Players &... • Answered on Mar 24, 2023
Can I attach a SL-EH780 to a RS-EH760
3/24/2023 5:26:09 PM • Audio Players &... • Answered on Mar 24, 2023
ONN 390 clock radio. How do I turn the alarm OFF on it please?
Question edited for clarity.Question moved to Clock Radios.Disabling the Alarm•? Press the AL1 or AL2 buttons repeatedly until the indicator is no longer lit.ONN Digital Clock Radio User Guide - Manuals+ - manuals.plusManuals+https://manuals.plus > onn > digital-clock-radio-manualJul 16, 2021 - ONN Digital Clock Radio User Guide ; 2 Information and Safety Instructions. 2.1 Important Safety Instructions. 2.2 ; 5 Clock & Sleep Timer. 5.1 ...
3/21/2023 1:09:07 AM • Audio Players &... • Answered on Mar 21, 2023
Weconic powered mixer user manual
Question moved from Misc to 'Mixers'. It need the model number in the search query. It looks to be Australian and we are in North America. This should work better for you. https://www.google.com/search?q=Weconic+powered+mixer+user+manual ..
3/19/2023 4:42:56 AM • Audio Players &... • Answered on Mar 19, 2023
My Centre speaker for my SP-PWC3 no longer works. Is this a easy repair? It is the amp and not the speaker as the speaker itself works with other lugs. Can I acquire another Mosfet? and replace the de
Unfortunately, it is not likely that you can replace the Mosfet yourself. The Mosfet is part of the amplifier circuit, and it is highly likely that the amplifier board will need to be replaced. Replacing the amplifier board is a complex process that is best left to a qualified technician.
3/17/2023 11:16:12 AM • Audio Players &... • Answered on Mar 17, 2023
How to set alarm Ikea Slabang clock
1. Press and hold the "+" or "-" button to enter the alarm settings. 2. Press the "+" or "-" button to choose the desired hour for the alarm. 3. Press the SET/RESET button to confirm and move to the minutes setting. 4. Press the "+" or "-" button to choose the desired minutes for the alarm. 5. Press the SET/RESET button to confirm and move to the alarm mode setting. 6. Press the "+" or "-" button to choose the desired alarm mode (i.e. one time, daily, or weekdays). 7. Press the SET/RESET button to confirm and activate the alarm. The ALARM indicator light will turn on when the alarm is active. 8. To turn off the alarm, press the SET/RESET button. The ALARM indicator light will turn off when the alarm is deactivated.
3/17/2023 10:54:18 AM • Audio Players &... • Answered on Mar 17, 2023
2answers
AWA 2528 Turntable With CD Player and Recorder. Unable to get functions on it. Power is connected and standby button operates, but then the function button does not respond.
Question edited for clarity and spelling, 'bottom' to 'button'. Question moved from Televisions category. You may be able to clean the workings behind the button with electrical contact cleaner. If that doesn't work, you will need a repair technician. https://www.google.com/search?q=awa+model+2528+function+button+not+working ..
3/15/2023 12:32:41 PM • Audio Players &... • Answered on Mar 15, 2023
How can I turn off shuffle mode in my playlist on alexa?
You can turn off shuffle mode in your playlist on Alexa using the following steps:
  1. Open the Alexa app on your mobile device.
  2. Tap on the "More" tab at the bottom of the screen.
  3. Select "Music & Books" from the list.
  4. Tap on "Amazon Music" or the music service that you are using.
  5. Tap on "Playlists" and select the playlist you want to play.
  6. Tap on the play button to start the playlist.
  7. While the playlist is playing, tap on the bar at the bottom of the screen to expand the player.
  8. Tap on the "Shuffle" button to turn it off.
Alternatively, you can say "Alexa, turn off shuffle" while the playlist is playing to turn off the shuffle mode.
3/15/2023 4:48:29 AM • Audio Players &... • Answered on Mar 15, 2023
Zoom R16 Multitrack SD Recorder Controller and Interface. I am trying to great a new project by pressing the project button but always display (save to No.000) could not go to new project?
Contact the maker Support for strangeness like that.
R16 Multitrack Recorder - ' ZOOM
Zoom Corp https://zoomcorp.com > multi-track-recorders > r16 The Zoom R16 instantly transforms any environment into a recording studio. Not only does it offer 16 tracks for recording, it can also be used as a DAW ...
3/14/2023 2:16:59 AM • Audio Players &... • Answered on Mar 14, 2023
Lexar Flash memory card - 32 GB - Class 4 - SDHC Logo
1 questions posted
Top Lexar Audio Players & Recorders Experts
August Brown
August Brown
Are you a Lexar Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Lexar Audio Players & Recorders
Most Popular Question
memory card error
  • Audio Players & Recorders
