20 Most Recent
Numark M2 2-Channel DJ Scratch Mixer 3-Band Equalizer Questions & Answers
My numark 5000fx lights up when turned on but does not register my technics on any of the channels
If your Numark 5000FX mixer is not registering your Technics turntable on any of the channels, there are a few things you can try:
- Check your cables: Make sure that your RCA cables are plugged in correctly and securely. If you are using a phono preamp, make sure that it is powered on and connected properly.
- Check your switch settings: Make sure that the switches on the back of the mixer are set correctly for the type of input you are using (line or phono).
- Check your levels: Make sure that the input levels are turned up and that the fader for the channel you are using is not muted or turned all the way down.
- Check your ground wire: If you are using a turntable, make sure that the ground wire is connected properly to the mixer.
If none of these steps work, there may be an issue with either the turntable or the mixer. Try testing the turntable on a different mixer or testing a different turntable on the Numark mixer to determine which component is causing the issue. If the mixer is the issue, it may need to be repaired or replaced.
Ok i just purchased my idj3 and installed all the
Make sure you install the software in the CD provided with the iDJ3. IF you already have, try to uninstall, restart and then reinstall. Sounds like the drivers for your device was not properly loaded to your PC which cause it not to recognize. If it still doesn't work after that, I suggest that you contact Numark tech support for further troubleshooting at this link:
http://www.numark.com/content54
Good luck and vote this solution if it helped you. Cheers
What does the fuse look like in a ns7 numark and were do they sell parts for it.
Posted by Deric Fielder on Jun 06, 2019
Hello Deric, indicates the Numark model you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Deric, indica modelo del Numark del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
