20 Most Recent
Anycom BSH-100 Consumer Headset Questions & Answers
Can't figure out how to
you must put your blue tooth device into discovery mode most manufactures use the power button,by holding it for 6 to 10 seconds while turning it on will put it into discovery mode and if you have your bt power turned on in your phone menu then you can search or add new device,once they have paired it will ask for a pin or pairing code .Most blue tooth device manufactures use a 4 digit pin code they are as follows 0000,1234,9999,or 1111 i hope this helps
My battery broke and i need a new one, is there
if it has a battery that can be replaced then i would take it to like a battery express or a battery plus store. Where they can attempt to open the unit and size out the battery. As online i cant find any information about the unit. If you know the battery size i can help you price it out online. It says its a Rechargeable 300 mAh Lithium-Ion Polymer battery that is easily changeable.
if thats the case add an additional comment with the battery size and i will find it online for you to be able to order. i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
How to change the battery in my Anycom HCC-250
A rechargable Li-Polymer battery should be included with a charger for it when you bought it.
Note:
It is recommended to charge your Car-Kit when it is not in use.
Please note that "inserting" charger will cause a device reset. However, when the Car-Kit is in charging (the charger has been inserted), the Car-Kit is in normal
operation
