20 Most Recent
Kensington 72223 (72213) Mouse Questions & Answers
Cursor
You may want to verify that the autoswitchoff (Allow the computer to turn off this device...) is disabled or grayed out; right click on my computer, click on Properties, click on the Hardware tab, click on the Device Manager button, expand your Mice and other pointing devices, right click on your mouse, click on Properties, click on the Power Management tab. You can also try updating the drivers. You can also do this on the USB Root Hub if your mouse is USB connected.
Hope this works for you and post back how things are or should you need further information. Good luck and kind regards.
I have lost my pin for my kensington bluetooth keyboard. How do I start again
Power on keyboard with 5 seconds button on. Keyboard will start with LED slow two flash mode.
Go to Device menu and "Add a device". Select Keyboard.
On the UI keyboard, input "0000" (no enter), and touch "add".
Then on the physical keyboard, input "0000" + Enter.
It should make start connecting.
The UI changes into connecting view. But it already connected.
You can test with pushing "Windows Key" on the physical keyboard.
After connected, both LED on keyboard was automatically turned off. It is still working normally.
My kensington trackball mouse will not work on your games.
Long ago Kensington never made the change to their driver when Microsoft went from DirectX 11 to 12
I called them and they refused to listen to me.
Very poor caliper of people in charge there.
Shame as the Trackball is a very good alternative to both the mouse and a joystick.
If they would update the driver then the trackball maybe a popular way to play games
The only way you can get it to work is to plugin another mouse
It will then work with all games
Kensington K72227 mouse
The mouse is too old and Kensington's website no longer supports it. Time to buy a different brand.
