20 Most Recent
Sharp AQUOS LC-60LE820UN 60 inch LED HDTV Questions & Answers
1 short 1 long blink on sharp aquos LC-60LE820UN
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. Search the site by type in the "
brand name" to your device, in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
Hi I have a Sharp aquos tv that won't turn but does weird things. is there an easy diy way to fix this.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Slow wireless connection
Make sure you have a n series wireless router. Also wireless routers especially g, n series, or 2.4-4.8 are line of site frequencies. That means you will get better reception if your wireless device is in the same room as your router.
How can I make the text sharp on Magnavox model 22ME601B/F7?
- Check HDMI Cable Connection: If you're using an external device like a cable box, gaming console, or streaming device connected to the TV via HDMI cable, ensure that the HDMI cable is securely plugged into both the TV and the external device. A loose connection can cause intermittent resolution adjustments.
- Adjust Picture Settings: Navigate to the TV's menu and check the picture settings. Look for options related to display resolution, aspect ratio, or picture mode. Ensure that the settings are configured correctly for your viewing preferences. Try resetting the picture settings to default and see if the issue persists.
- Update Firmware: Check if there are any firmware updates available for your TV. Sometimes, software updates can fix bugs or issues related to display resolution adjustments. You can usually check for updates in the TV's settings menu or visit the manufacturer's website for instructions on how to update the firmware.
- Check Signal Source: If you're experiencing resolution adjustments while watching content from an external device, such as a cable box or streaming device, make sure the signal source is sending a consistent signal. Issues with the signal source can sometimes cause the TV to adjust its display resolution.
- Reset TV: Try performing a factory reset on your TV to restore it to its original settings. Keep in mind that this will erase any customized settings and preferences, so you may need to set up the TV again after the reset.
- Contact Magnavox Support: If the issue persists after trying the above steps, it's possible that there may be a hardware problem with the TV. In this case, it's recommended to contact Magnavox customer support for further assistance or to inquire about repair options.
By following these troubleshooting steps, you should be able to diagnose and resolve the issue of your Magnavox TV constantly adjusting its display resolution.
Hope this helps
How do I operate Sharp LCD TV remote control
First of all
1. **Power On/Off:** Use the "Power" button.
2. **Changing Channels:** Use "Channel Up" and "Channel Down."
3. **Adjusting Volume:** Use "Volume Up" and "Volume Down."
4. **Input Selection:** Use "Input" or "Source" to choose input devices.
5. **Navigating Menus:** Use navigation arrows and "Enter" or "OK."
6. **Mute Function:** Use the "Mute" button.
7. **Number Pad:** Input channel numbers or perform numeric functions.
8. **Special Functions:** Access features like "Menu," "Exit," "Subtitle," or "Info."
9. **Teletext/Closed Captioning:** Access these features if applicable.
10. **Smart TV Features:** Access smart features, apps, or online content if applicable.
11. **Batteries:** Ensure the remote has fresh batteries for responsiveness.
For model-specific details, always refer to your Sharp TV's user manual. If you provide your TV's model number, I can offer more tailored instructions.
