20 Most Recent Kodak Dock Series 3 Laser Photo Printer Questions & Answers
It sounds like defective batteries if the printer unit works otherwise,
Kodak Dock... • Answered on Mar 06, 2009
did you try to change the orientation to landscape or portrait? you can also check the printer properties and make sure that you have the right size paper selected
Kodak Dock... • Answered on Jan 11, 2009
A very small piece of the paper you pulled out could be lodged somwhere. Very carefully check for this, with a torch! You would be surprised how small a piece can be left behinfd and cause havoc. How do you know it is not a software problem as well. You can have more than one issue amd one can mask the other. Do try reinstalling with pc. Your paper sensor may have been damaged too. This would reult in no paper pulled in, as it cannot sense it is there. Never jam or force paper in as this can also damage the sensor and feeder. You will not know if it is the sensor until you eliminate all else.
Kodak Dock... • Answered on Jan 02, 2009
It could be a few things.
How does it print if you take the memory card out of the camera and plug it into the printer?
How does it print if you print from the computer?
Kodak Dock... • Answered on Dec 24, 2008
How did you manage this? I am not being rude, what i mean is, how did it occur, did it print and then jam, did you put it in and then try to print without success. Is it printing even though it won't come out. You may have put it in slightly askew and it can contact to print but jams when you try to pull it out. try gently and very very softly turning it left and very very gentle pulling, really slow. try this in the opposite direction too. Be so very gentle as if it is at an odd angle you could damage your cartridge or printhead.
Kodak Dock... • Answered on Aug 08, 2008
Uninstall the drivers , restart your computer and then reinstall the drivers from the website who made the printer.
Kodak Dock... • Answered on Apr 14, 2008
hi there, try uninstalling your printer and reinstalling it again but use the most up to date driver for it which can be downloaded from http://wwwuk.kodak.com/global/en/service/products/EKN030179.jhtml?pq-path=6638 hopefully that'll solve the problem if not check the cartridges make sure they are seated properly might even be worth replacing them with new ones hope this helps
Kodak Dock... • Answered on Aug 19, 2007
Lines in printouts indicate lots of issues. Clogged printheads...even in a new printer, damaged cartridge, or air bubbles in ink. Take out the cartridges, clean the heads and the docks printhead, replace and try again. If no success, try standinf the cartidges upside down on wet paper towel, and bleed ink a little. This eliminates air bubbles. Try printing now. Clean heads with printer program too. If still no success, follow consumer rights which says you are entitled to a product doing what it says it should for a reasonable amount of time (if it turns out to be a faulty dock. Try a new cartridge too after claening to eliminate damaged cartridge.
Kodak Dock... • Answered on Aug 11, 2007
Kodak 8800 Printer Repair Manual - Page 2 - Mini Lab Help
www.minilabhelp.com > ... > Kodak
Feb. 24, 2017 - I too would like the Kodak 8800 service manual please, as our printer is randomly displaying the error "Service 3.43.8" and I wish to troubleshoot ... Missing: 3.42.8 ‎' Must include: 3.42.8
KODAK Photo Printer 8800
resources.kodak.com > pdf > manuals > professional
PDF KODAK Photo Printer 8800. User Guide ... Kodak is a trademark of Eastman Kodak Company. ... A KODAK Photo Print Kit that contains the correct size paper and ribbon ... Error. Red. An error has occurred. 1. Press Menu to enter Setup Mode. 2. ... If the printer has been dropped or damaged, be sure a qualified service. Missing: 3.42.8 ‎' Must include: 3.42.8
Kodak PROFESSIONAL 9810 Thermal Photo Printer ... - Fixya
www.fixya.com > support > p460640-kodak_professio...
Free expert DIY tips, support, troubleshooting help & repair advice for all Office Equipment ... Kodak 8800 paper emply ... Kodak 9810 barcode sensor error.
Kodak Office... • Answered on Mar 07, 2021
Kodak Office... • Answered on Feb 03, 2021
https://www.manualslib.com/manual/89041/Kodak-Esp-C315.html?page=4#manual
Kodak Office... • Answered on Oct 14, 2020
Kodak Dock Series 3 Laser Photo Printer Logo
21 questions posted
Top Kodak Office Equipment & Supplies Experts
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kodak Office Equipment & Supplies
Most Popular Question
paper will not feed
  • Office Equipment & Supplies
