20 Most Recent Kodak EASYSHARE Printer Dock 6000 Thermal Photo Questions & Answers
Can you tell me how the head was jammed in the first place.
Is the head jammed in the middle of the carriage? If it's jammed in the dock then you might need to open the covers. Then you need to investigate further. If your not confident with mechanical parts that could be a problem. The obvious one "switch off and on, try resetting the mechanicals" possibly severlal times.
Kodak EASYSHARE... | Answered on Jan 30, 2015
hey there,hope this helps mate http://drivers.downseeker.com/download-kodak-photo-printer-6400-driver-v130_4.15.03/
Let me know if not :)
Kodak EASYSHARE... | Answered on Feb 01, 2011
Maybe your rollers inside the printer that feed the paper in, are not functioning the way they should. This could just simple to fix, or could mean you having to purchase a new printer.
Not sure how you would fix this.
Hope this helps!
Kodak EASYSHARE... | Answered on Feb 05, 2010
try to visit this website to download the latest software and drivers kodak.com/go/PD6000support
Kodak EASYSHARE... | Answered on Nov 19, 2009
Click here, its a link to kodak's easyshare printer dock 6000 exactly at the driver download.
Kodak EASYSHARE... | Answered on Nov 01, 2009
Kodak Fax keep saying line busy
Kodak EasyShare... | Answered on Jul 01, 2016
To me it sounds like the rollers are shiney so may need cleaning
Kodak EasyShare... | Answered on Mar 05, 2016
the beautiful thing about printer is that the software is preloaded in the hardware itself . simply meaning all you have to do is plug in your printer straight into the usb port of your computer. while the printer is on when that happens the computer will download the necessary driver to make sure the printer is functional!
then you will also see a pop up to download their software . in that software is your salvation, for there while be a step by step tutorial on how to successfully install your new printer.
Kodakcustomer service is great if you catch a hiccup just be sure to contact them and i believe they will walk you through the process.
here is a bing search to get you in the right direction!
http://www.bing.com/search?q=kocak+printer+technical+support&form=U280DF&pc=U280
Kodak EasyShare... | Answered on Dec 29, 2015
Take the cartridge out and dab on wet paper towel and clean the print head with alcohol using a q-tip.Be sure to unplug the power first.
Kodak EasyShare... | Answered on Dec 03, 2015
Replace cartridge, but, before run the print test (cartridge alignment as well as cartridge cleaning process).
Kodak EasyShare... | Answered on Jun 08, 2015
You can go to the KODAK Web site but it indicates they no longer support that system since 2012.
http://support.en.kodak.com/app/answers/detail/a_id/3569/~/how-do-i-resolve-easyshare-software-error-codes%3F/selected/true
Kodak EasyShare... | Answered on Nov 04, 2014
Run the clean nozzle maintenance.
Kodak EasyShare... | Answered on Sep 06, 2014
To replace an ink cartridge on a Kodak ESP C310 follow these steps:
1) Make sure your printer is on.
2) Lift the printer access door, and wait for the carriage to move to a position where you can access it. The ink cartridges are located in the printhead.
3) Pinch the tab on the ink cartridge.
4) Lift the ink cartridge out of the printhead.
5) Remove the new ink cartridge from its bag.
IMPORTANT:To prevent the printhead from drying out, insert the ink cartridge into the printhead immediately.
6) Remove the protective cap from the cartridge.
7) Insert the ink cartridge into the printhead.
8) Press down on the ink cartridge tab until you hear a click.
9) Close the printer access door.
That completes changing the ink cartridges.
Thank
Mark
Kodak EasyShare... | Answered on Aug 25, 2014
Kodak EASYSHARE Printer Dock 6000 Thermal Photo Logo
10 questions posted
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Muntejaya Ginting
Muntejaya Ginting
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
need hardware download
  • Office Equipment & Supplies
