20 Most Recent Kodak i260 Duplex Color Scanner Questions & Answers
Clean Optical path to camera lenses back and front, then Calibrate through the Kodak SVTool.
Kodak i260... | Answered on Jul 15, 2015
1. clean mirros ,
2. change imaging guide
3.camera inside senser dust clean
Kodak i260... | Answered on Jun 30, 2014
cluch motor problem or senser probelem,
tray first front side scan only its pass the paper than
scan next back side if not pass problem from fron or back senser
it`s problem from adaptor , or from lamp regulator pcb is before conect to lamp wire
try to install microsoft framework 3.0 or latest first and than install window 7 or xp
the lamp is more than 3 year old , it`s require replace for heat problem
Hi Kevin
Have you cleaned the filter on the cooling fan ? It is underneath the scanner secured by 3 small torxs screws
Kodak i260... | Answered on Dec 07, 2011
This sounds like a sensor issue, try cleaning the sensors, DO NOT use compressed air. Also try recalibrating the scanner. If all fails it may be a bad sensor, call kodak 800-822-1414 and they should be able to assist you.
Kodak i260... | Answered on Sep 15, 2011
My scanner i260 do not scan properly, it present a distortion in the image, Could you help me?
Thanks a lot
Kodak i260... | Answered on May 23, 2011
You have to clean both CCD& sensor.Then try to caliberate the scanner. If caliberation happened scanner is okay. After cleaning caliberation not hapening change imaging guide or lamp. in this error imaging guide having problem
Kodak i260... | Answered on Jan 28, 2010
This is a non Vista compatable product.
It may run on Windows Vista 32bit Business though.
Kodak i260... | Answered on Jul 05, 2009
Popular Tags
34 questions posted
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
I Kodak
  • I Kodak
Most Popular Question
kodak i260 svanner not working
  • Office Equipment & Supplies
