20 Most Recent
Kodak I620 SHTFEDSCAN Path-Through Scanner Questions & Answers
I620-auto feeding multiple sheet
I opened the hood on the machine, and between the first two intake rollers on the bottom, there is a small rubber strip. This strip comes packaged with a sticky yellow tape to protect the rubber. When it was installed, no one removed this tape. After doing so, the machine feeds great. Hope this helps someone else who may be experiencing a similar feed issue.
I620 scanner
Is the scanner scanning normally otherwise? Try scanning a printed matter with white background and if it is okay, then the streaking may be because of excess brightness chosen. Check if the paper movement is at constant speed. If it is smooth paper, it may slip and the same area may scanned again, appearing like a streak.
S. Moha, Chennai
