20 Most Recent NEC Dterm Series I Dtr-16d-2 / 780048 Black 16 Button S Questions & Answers
0answers
I am trying to connect a NEC t-710 tuner to a NEC Av350E AMP - how do I do that?
A tuner would typically have an output labelled "line out" or similar and the amplifier would usually have either a "line in" socket or a dedicated tuner input and it is a matter of connecting the two with a suitable lead.
2/7/2019 12:40:11 AM • NEC Audio... • Answered on Feb 07, 2019
NEC VH-605 VCR - Very Snowy Picture
Video head needs thorough cleaning. If no head cleaner, then run a few long tapes through it in the fast scan mode since the tape itself is abrasive and will over time remove debris from the heads. If that does not do it, try a chemical cleaner to dissolve the material.
9/1/2017 12:39:35 PM • NEC Audio... • Answered on Sep 01, 2017
0answers
Nec microwave
Be the first to answer 4/13/2014 9:05:22 PM • NEC Audio... • Posted on Apr 13, 2014Be the first to answer
0answers
0answers
No mixer, audio to have
if your computer came with a motherboard disc the sound drivers could be on it you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling a yellow? question mark means you need to install/update driver to do this right click to install driver also click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps don
2/24/2011 5:50:34 AM • NEC Audio... • Answered on Feb 24, 2011
0answers
I have an NEC
Be the first to answer 10/22/2010 7:54:55 PM • NEC Audio... • Posted on Oct 22, 2010Be the first to answer
I'm looking for the manual
Hi, here is the link to NEC see if your Product is there -
http://www.nec-itplatform.com/-Products-Information-
8/20/2010 8:04:55 AM • NEC Audio... • Answered on Aug 20, 2010
I cannot open my computer because license of
You might just be able to go to:
Start > Control Panel > System
You should see a place where the product key is. There might be a button there to activate or put in a new key. What you need to do is look at the sticker on the side of your computer and there will be a Windows Product Key there. Just input that one in because it is the correct number.
That should work. I just had the same problem on mine. It had some number already in it but it was wrong. I had to get the real number off that sticker. Once you buy Windows, it doesn't go away, it is yours forever - unless you just downloaded a trial version or something.
12/7/2009 9:32:03 PM • NEC Audio... • Answered on Dec 07, 2009
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS. Question moved from Cars and Trucks category. Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries. How long is the warranty on AfterShokz? While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase. Jan 11, 2019
How To File A Warranty Claim For Your SHOKZ Headphones
https://www.google.com/search?q=Openfit+Shokz+battery+replacement ..
4/16/2024 4:58:24 PM • Audio Players &... • Answered 3 hours ago
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first. But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
4/16/2024 5:57:29 AM • Audio Players &... • Answered 14 hours ago
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
4/10/2024 6:11:44 AM • Audio Players &... • Answered on Apr 10, 2024
NEC Dterm Series I Dtr-16d-2 / 780048 Black 16 Button S Logo
Popular Tags
8 questions posted
Top NEC Audio Players & Recorders Experts
Tesfay
Tesfay
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a NEC Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • NEC Audio Players & Recorders
Most Popular Question
work phone flashing green light
  • Audio Players & Recorders
