20 Most Recent JBL Jembe Two-piece Entertainment Speakers Questions & Answers
Sounds like you have them plugged into the wrong jack
JBL Jembe... | Answered on Jan 16, 2013
Check there is a signal going to it.
Check the amplifier is working.
Check the bass speaker is not blown.
JBL Audio... | Answered on Dec 28, 2019
Assuming Bluetooth mode. Insure Bluetooth is enabled on the iPad and the JBL and that they are in the pairing mode.
Sometimes I find it necessary to restart a device to get its Bluetooth pairing mode to connect to the device I am trying to connect it to, such as a speaker or even my car.
Try doing default factory settings.
Step 1. Press the "Power" button located on the top center part of your JBL Charge 4 Bluetooth speaker. The speaker will be powered on when the LED backlight under the Power button is lit.
Step 2. Hold down the "Bluetooth" and "Volume Up" buttons at the same time for roughly three seconds. The Volume Up button looks like a plus sign. Additionally, it's important to hold down the "Bluetooth" button in the center of the device next to the Power button, as it's easier to hold down. After three seconds, the LED ring around the Power and Bluetooth buttons will briefly light up before the JBL Charge 4 powers down.
Step 3. Press the "Power" button again to turn the JBL Charge 4 Bluetooth speaker back on. The Charge 4 will instantly turn on in Discovery mode, with the Bluetooth LED blinking on and off, and the speaker making a pinging sound. This confirms that you've successfully reset your JBL Charge 4 to its default factory settings. You'll need to pair or re-pair any devices you want to play audio through the JBL Charge 4 speakers with the device.
JBL Audio... | Answered on Nov 24, 2019
Here is the link below for JBL Charge CE1588
That is a bluetooth speaker sir. Standard device. ANY device with bluetooth should be able to use the speaker with no drivers other than the ones included on the playing device
JBL Audio... | Answered on Nov 03, 2019
Hello
For the JBL Awake
I just had the same issue and i found a way to solve this :
1. Unplug the power supply
2. Plug it back while holding the [ON/OFF] button
3. The screen shows “UP9” again
4. Do the update with the JBL Music app (I did it with my old iPhone 4s plugged on the 30pin connector)
5. Finish the firmware update ... until the app tells you to unplug the power before restarting the device
(Sorry for my bad English, i’m French)
JBL Audio... | Answered on Oct 25, 2019
Just visit the site linked here; only and if you're technically qualified. If not, contact any service technician to repair this set.
https://electronicshelponline.blogspot.com/
If you're aware, you'll get something. If not nothing. OK?
JBL Audio... | Answered on Oct 20, 2019
To reset JBL LINK VIEW PRESS THE PHYSICAL
VOLUME UP & DOWN BUTTON TOGETHER
FOR ABOUT 8 SECONDS ....CHEERS
JBL Audio... | Answered on Oct 16, 2019
JBL Jembe Two-piece Entertainment Speakers Logo
Popular Tags
1 questions posted
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • JBL Audio Players & Recorders
Most Popular Question
jbl speakers turn off own
  • Audio Players & Recorders
