20 Most Recent
Elliott's Car Radio Ford-COSF-18808-E Car Speaker Questions & Answers
Need wiring code for for radio f58f-18c815-aa
Are you replacing a head unit or just whant to know what wire so what on your existing unit. If you are replacing a hjead unit you should always buy the correct wiring harness for you vehicle wich you can purchase at any electronics store that sells car audio.
I would like to know how to decode car radios one
Hi, many people have this problem, and the only way to do this task is to contact your Ford dealership, give them the make and model of your radio and they should be able to find the code for it, for a price, which in my country (UK) is £40.00.
I have 87 merc cougar, someone cut the wires for
there should only be the main fuse for radio. but heres the the color codes
Constant 12V+
Green/Yellow
Switched 12V+
Yellow/Black
Illumination
Blue/Red
Dimmer
n/a
Antenna Trigger
Orange/Blue
Antenna
Right Front
Front Speakers
3 1/2" Dash
Left Front (+)
Orange/Green
Left Front (-)
Black/White
Right Front (+)
White/Green
Right Front (-)
Black/White
Rear Speakers
6" x 9" Rear Deck
Left Rear (+)
Pink/Green
Left Rear (-)
Pink/Blue
Right Rear (+)
Pink/Blue
Right Rear (-)
Green/Orange
hope that helps if u need more help feel free to email me at
[email protected]
Radio sound with a noise
Please take out the speaker and inspect it for a torn cone. At times, humidity, amp power or just wear and tear ruins the cone. Then you can replace the speaker or re surface the old speaker with a new cone. That will save you some bucks but may not be as well as buying another speaker. Also please use the same model and Ohms of it. 8 or 16 ohms
Car radio replacement
Does the radio power up but give no sound? If this is the case, you need to make sure the factory amplifier is first turned on. the aftermarket radio should have a remote turn on lead for amps. The Dodge caravans sometimes have Infinity sound systems in them and there may be a green wire with a red stripe in the factory side of the radio plug. This should be amp trigger. 12volts to this wire should give sound. If at all unsure, please consult a local stereo shop.
Car radio
need more info (have you tried adjusting balance control or any thing like this )..
Intermittant speaker failure
What's up Matt,
I would suggest it's either the head unit has a small electronic component in it that;s going bad, or when the factory wired that car they placed a wire incorrectly and it has chaffed it's insulation off over a period of time.
Good Luck
L8R
Soundstream vr-623b I need to know where the 5v power yellow wire gos
Soundstream VR-623B 6.2" Touchscreen High Resolution TFT LCD Car CD DVD MP3 Receiver w Built-in Bluetooth V3.0 Hands Free Calls Audio Streaming USB AUX SD Card Inputs LED RGB Colors AM/FM Radio Stereo
lost the manual that it?
say the word lost.
My second guess is
you installing this,
and do not understand cars power structures.
well, a radio head, like this has 3 power wires.
1: main power.
2: backlighting'.
3: memory wire.
4: some have electric antenna controls power.
the answer to #1 regardless of color. is it goes to . the fuse marked radio in the fuse box.
this is key on power, for accessories and ignition on.
Radio fuses
If it's an aftermarket CD player there's a fuse in the back of the unit. The car should have a fuse in the fuse box. Some CD players have a reset button behind the face you can use an ink pin to reset it
