20 Most Recent
Motorola Mobility XT3 QUENCH XT502 3.2MP ANDROID UNLOCKED PHONE Questions & Answers
Many pattern lock attampt but no benefit kindly guide me how to unlock motorola xt-502
Hi Sohil,
Sadly, if you're unable to get past the lock pattern, you'll have to perform a factory reset. Please follow the steps below to factory reset your device. Keep in mind this will delete all content from the phone.
Power off the device
Press and hold the R and M keys while pressing the Power button. You will see the red M logo on your screen then the screen with the Android-bot and a blue exclamation mark inside a white triangle
Once this screen appears, press both Volume Up and Down keys, then release to get the Android system recovery
Use the Volume Up and Volume down buttons to select wipe data/factory reset
Choose Yes -- delete all user data to confirm that you would like to wipe all data from the device and press the Return key
Your device should now cycle through the wiping/reset process and return to the Android system recovery screen
After userdata is cleared, the "reboot system now" option will be highlighted by default. Press the return key to power off/on your device
It will take a few moments to arrive at the initial Android Welcome screen.
Your phone will reboot and be back to factory settings. You can now set everything back up on your phone again.
Thank you,
Tom
Motorola Support
MOTOROLA PRO PLUS Factory Data Reset
4/26/2019 4:50:03 AM •
Motorola...
Answered
on Apr 26, 2019
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
