20 Most Recent LaCie (300950) 400 GB Hard Drive Questions & Answers
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
7/15/2009 6:19:00 AM • LaCie (300950)... • Answered on Jul 15, 2009
200 gb d2 extreme
The whining noise and the low clicking sound are indicate mechnical problem. My recommendation to you is to backup all the important data you have on it ASAP before it will crash and you will not able to do it !!!!
8/28/2007 11:52:52 AM • LaCie (300950)... • Answered on Aug 28, 2007
2answers
Hard drive is "full" though I only have 186G on it
hereĀ“s a thought! You can try running chkdsk cause maybe your freespace is being reported incorrectly! Open command prompt: Go to Start->Run then type cmd and press enter Run the chkdsk utility: where x is the drive letter of the removable drive at the prompt type chkdsk x: /f and press enter now windows will scan for filesystem errors and fix any if found. Also on another note, items in your recycle bin count towards the amount of used space! hope this helps regards, babb
7/5/2007 8:32:05 PM • LaCie (300950)... • Answered on Jul 05, 2007
2answers
I have problem with disk LACIE. He is write protection
Check the data recovery programme used for an idea or start again now you have your data back by re initialising and formatting the drive as a new one.
6/27/2022 7:20:03 PM • LaCie Computers... • Answered on Jun 27, 2022
I have the LaCie Porsche 500Gb external USB hard drive. is computer is unuble to detected the hard drive .show PnP problem .how to fix it?
Depending on your OS, use your disc utility and see if it has been initialised or not. If not initialise it and then you can format and use it as normal.
6/27/2022 7:19:12 PM • LaCie Computers... • Answered on Jun 27, 2022
Forgot password of lacie rugged hard drive
Did you get it fix ? Have the same drive and forget the password!! Need help
4/25/2022 5:11:24 PM • LaCie Computers... • Answered on Apr 25, 2022
My LaCie external drive isn't getting power
U should test for power at the connector that goes into the lacie with a voltmeter to make sure power supply and its wire are OK. If no voltmeter then use a automobile brake or turn signal bulb to see if it has power.
12/2/2021 10:39:59 AM • LaCie Computers... • Answered on Dec 02, 2021
I for got me password I don't even remember setting one up Lacie rugu3m2
Just an idea. When you set pass words or any important information write all information in a note book and keep it in a drawer someplace where you will not lose it. When things change write the new ones down and cross out the old ones. I save a lot of head aches that way.
1/22/2019 9:12:10 PM • LaCie Computers... • Answered on Jan 22, 2019
Hello, I have a LaCie D2 525 Super Writemaster. Stopped reading CD, slowly flashing it'sLED. No image on desktop. Eject button doesn't react and paperclip insertion activates eject but tray is stuck.
Pushing in the paperclip should unlock it, but if still jammed, may have to wreck drive by pulling off front of drive drawer thing. Maybe try putty knife to push cd down some of that's holding it from opening.
1/22/2019 4:25:39 PM • LaCie Computers... • Answered on Jan 22, 2019
I have a Lacie external drive when the power plug connection on the circuit board broke off. Can the circuit board be repaired or replaced?
Replace perhaps, but repair is most difficult. The electronics are miniature and it takes special tools to do repairs.
1/2/2019 7:13:50 PM • LaCie Computers... • Answered on Jan 02, 2019
Can I remove the disc from a LaCie 300770 250 GB drive and try it in another drive? The drive is not working, so I hope the disc is ok.
Two ways this can go. If you are talking about the entire hard drive pulling it out and plugging the whole drive into another pc. Then you're fine If you are talking about disassembling the hard drive and moving the disks inside. This is not something you can do. This is what you will need. 1) a certified clean room surgical grade 2) tape 3) A matching drive/ hd board down to revision number 4) presision screw tools. 5) patience. Or you will need to contact a professional data recover company.
12/29/2018 9:24:31 PM • LaCie Computers... • Answered on Dec 29, 2018
3answers
Lacie n2870 driver
You need a new driver for sure, and here you can find it driverupdate us. This tool usually keep my drivers up to date (perfectly for now) take a look
9/14/2018 12:27:06 PM • LaCie Computers... • Answered on Sep 14, 2018
How do I turn the LaCie 300722 DVD RW burner on?
Here is the user manual for your device: https://www.lacie.com/files/lacie-content/manual/d2_dl_dvd_toast7_en.pdf
2/9/2018 7:21:14 AM • LaCie Computers... • Answered on Feb 09, 2018
LaCie (300950) 400 GB Hard Drive Logo
5 questions posted
Top LaCie Computers & Internet Experts
Marvin
Marvin
shadow
Mike
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • LaCie Computers & Internet
Most Popular Question
lacie 320 gb hard drive acting as full
  • Computers & Internet
