20 Most Recent LaCie d2 (300769) 200 GB Hard Drive Questions & Answers
check if it is initialized in the disk manager
LaCie d2... | Answered on Dec 19, 2017
"It's dead, Jim"
Seriously? That drive is old enough to be in the 6th grade. If it is really imperative to get it working you can try percussive maintenance (slap it on the bottom), giving it the cold shoulder (putting it in the freezer for a day) or giving it shaken baby syndrome (give it a good cocktail shaking). If the issue is a stuck drive head or loose circuit board that may fix it. If it's just dead of old age (thermal fatigue, tin whiskers, etc) it's time to recycle. If it's just the drive that's dead it might be possible to reuse the case, but, if it's the IDE drive case don't bother.
LaCie d2... | Answered on Apr 03, 2015
well, there is this device by LaCie that allows you to connect usb and firewire stuff into the same hub
http://cableorganizer.com/lacie-usb-hub/
LaCie d2... | Answered on Apr 11, 2011
My guess is that your thumb drive was somehow
infected with a virus!
( The thumb drive has probably been connected to internet)
It sound like a virus infection because all the drives
has been affected !
Hope this help! Please vote
LaCie d2... | Answered on May 12, 2010
I support the comments of (fire sine) I have the d2 120gb Lacie and it was down for two years.  I took it to my apple guys and they said that I needed to go to a data recovery service which would cost a gang of money.  Come to find out, when I decided to update my internal hard drive on my Mac Pro, I had to buy a SATA, IDE, USB 2.0 adapter to back up the internal and transfer to the new internal. Long story short, something said, Hey try and open the Lacie and bypass the board in the enclosure and connect directly to the Western Digital drive inside.  AND WHALA! I got my info, so all I need is a new enclosure.
LaCie d2... | Answered on Mar 11, 2010
the situation here is ahppening to all external sata or Esata drives what happens is the external closure has a usb controller when this dies the drive doesn ot spin up or does not reconise simple solution buy a external drive encloser and transfer the drive to it and that will work. thanks and please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
LaCie d2... | Answered on Nov 24, 2009
Hi, Your query, "Where do I buy parts?" depends on your location. Pls try Google for an "IDE to USB Adapter or enclosure." Based on previous work on similar problems, it is very rare for the "bridge or internal cabling" to go bad. More often than not, it is the actual drive that is at fault. Hope this be of some help/idea. Post back how things turn up or should you need additional information. Good luck and kind regards.
LaCie d2... | Answered on Dec 15, 2008
run diskmgmt.msc create a partition then format it. done. if no driveletter .. assign it.
LaCie d2... | Answered on Jun 01, 2008
it most likely means the enclosure has failed. Especially if it is not making and odd sounds. 4 out of every 5 of those things just needs a new enclosure. If you need the data, then break the label on the rear, Unscrew the 2 screws, and test the drive in a computer or different enclosure.
LaCie d2... | Answered on Oct 23, 2007
Just an idea. When you set pass words or any important information write all information in a note book and keep it in a drawer someplace where you will not lose it. When things change write the new ones down and cross out the old ones. I save a lot of head aches that way.
LaCie Computers... | Answered on Jan 22, 2019
Pushing in the paperclip should unlock it, but if still jammed, may have to wreck drive by pulling off front of drive drawer thing. Maybe try putty knife to push cd down some of that's holding it from opening.
Replace perhaps, but repair is most difficult. The electronics are miniature and it takes special tools to do repairs.
LaCie Computers... | Answered on Jan 02, 2019
Two ways this can go. If you are talking about the entire hard drive pulling it out and plugging the whole drive into another pc. Then you're fine
If you are talking about disassembling the hard drive and moving the disks inside. This is not something you can do.
This is what you will need.
1) a certified clean room surgical grade
2) tape
3) A matching drive/ hd board down to revision number
4) presision screw tools.
5) patience.
Or you will need to contact a professional data recover company.
LaCie Computers... | Answered on Dec 29, 2018
LaCie d2 (300769) 200 GB Hard Drive Logo
Popular Tags
18 questions posted
Top LaCie Computers & Internet Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • LaCie Computers & Internet
Most Popular Question
lacie d2 external drive
  • Computers & Internet
