20 Most Recent
Lexmark X3350 Thermal Inkjet Multifunction Printer (Receive a $50 Mail-In when you purchase ... Questions & Answers
Medownload my lexmark x3350 to
You can download the Lexmark X3350 driver by visiting the Lexmark website at
http://bit.ly/ffZS77. Select your operating system -> download the driver -> execute the file -> follow the instructions on your computer screen.
How do i set the time on a lexmark x464
Usually you need to access the embedded web server on the printer by typing the IP address of the printer into your web browser address bar. This will open a window that will have all the settings available.
The display reads: the printhead is not supported by the all in one
Please make sure the print head is seating properly as it should.
Another reason could be the contacts of the print head are not connecting properly with the main printer due to dirt. Remove the print head, clean the contacts of the print head and where it seats at the printer. hope this will help
Machine will not print
Yes it is true machine will print because its maybe need some type of repairing or the machine is not a printer of a photocopy
OCR doesn't work with WINDOWS 7 and my Lexmark X5650es printer
Try this approach:1. Uninstall your existing printer driver. On your computer, go to Start menu > Programs > Lexmark X5600 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.2. When your pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.3. Use the link below to download and re-install the corresponding printer driver for your operating system:-
Lexmark X5650 Printer Driver for Windows 7 32-bit-
Lexmark X5650 Printer Driver for Windows 7 64-bitSimply follow the instructions on your computer screen to complete the installation.4. To re-install the Lexmark OCR scan software, insert the printer software installation CD in your pc CD-ROM drive.5. Click on Install > Install Additional Software > select the Lexmark OCR Scan Software > continue with normal installation steps.Then try to create a PDF or Scan and Edit text (OCR) to verify that the problem is fixed.If that doesn't help, please contact Lexmark Technical Support Center at 1-800-539-6275 for additional assistance.
