20 Most Recent
Lexmark X63 InkJet Printer Questions & Answers
I have a lexmark x63
hi Cavschick104.
this is all i could find out.
COMPLETELY uninstall the printer and
reinstall it..... It may have occurred if you have your printer connected
during the installation of XP.... it is normal practice to keep the printer
disconnected during an upgrade or clean install.... and then correctly
install it afterwards.
This from the Lexmark site:
Remove the USB cord and the power cord from the back of the printer, and then remove
the USB cord from the back of the computer.
Uninstall the printer/scanner software from the Program menu and restart the system.
Check the part number on the setup CD. If it is not P/N 13H0350, you need to download
the XP driver from the Lexmark web site,
www.lexmark.com.
When the PC has restarted, log in as an administrator and insert the setup CD into
the CD-ROM drive
Click OK and Install now.
Follow the setup instructions to install the scanner software. When you see Connect
the USB Cable to the printer on the screen, first attach the power cord to the
printer, then attach the USB cord to the printer, and finally attach the USB cord to
the computer.
Follow the setup instructions on the screen to complete the printer software
installation.
If you want technical support of Lexmark, you can contact us on
Lexmark Printer Support 1-866-877-0191. We are always available with technical experts for your help. For more information, click
https://goo.gl/bpBgcR
Lexmark Printer 1 866 877 0191 Help Support Service...
I am trying to install my printer to a different
Lexmark is one of the most popular printer manufacturers today. It has gained this popularity owing to the fact that unlike all other companies it has kept its prime focus only upon its printer manufacturing division, specifically LaserJet printers. In case your printer is not working and your warranty has run out of its validity, you can contact third party technical support company over their specified
Lexmark printer support phone number to resolve all printer issues at very nominal charge.
I have the lexmark X63 printer and I need to use
Depending on the age difference between your operating system and the printer, you may get some functionality by doing this:
Power down your computer system and then connect the printer.
Make sure the printer has power and is turned on.
Restart your computer.
Windows may recognize it and install the appropriate driver.
Watch the lower right-hand area of your monitor during the boot. If Windows sees it at all, it will open a message box and either tell you it is installing the driver or it will tell you to insert the disk that came with it (which you don't have.)
Going to the Lexmark website, you should find downloadable installation packages for virtually any printer they ever built.
You might create a new folder prior to trying to download and give that folder as the destination for the download.
Normally, you will be able to start the installation procedure from within that folder.
Lost my installation disc X63 lexmark
CLICK HEREthat link above will take you to their site just choose in the top right hand corner what country your in then you can download all the software and drivers you need for that printer.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Need manual for x63 fax machine
http://www.lexmark.com/publications/eng/x63/index.html
here is the link for the starting guide and manual.
Hope its what you need
Whenever I try to print
I will need to know what procedures you have already followed. For example:
Have you turned the printer off at the power source and then turned back on again?
Have you opened the print queue in windows and cancelled any spooled files?
Has the printer worked correctly previously and now has this problem, or is this the first time you are using it?
Please provide as much information as you can so that I can help.
Printer message display: 'clear system then press
The error has something to do with the cartridge. To clear the error, try this:
1) Remove the power cable for 2 minutes and the USB cable from behind the printer.
2) Press and hold down the stop clear button and reconnect the power cable back to printer.
3) The printer LCD screen should clear the memory error.
4) If the same error message persist on the LCD screen, please follow the instructions below.
5) Unplug the power cable for 2 minutes and USB cables from behind the printer and open the printer cover and remove both ink carts.
6) Repeat step 2 and Install both cartridges then the screen will display Cartridge's clean, press start.
Have an Lexmark X63 but
You can download a manual from http://support.lexmark.com/index?locale=en&segment=SUPPORT&startover=y&userlocale=EN_US&question=x63&productCode=LEXMARK_X63&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X63&searchid=1267661982439#2
Lexmark X63 jetprinter
Hi, try carry out maintenance check on the printer, enter main settings
on the printer, scroll down to maintenance and select the clean
cartridge option, after the cleaning has finished, you can equally
align the cartridges by carry out alignment of the printer.
If this still persist, you might need to change the cartridge.
I wish you best of luck.
How to feed document when faxing
Go to
www.lexmark.com and scroll the page until you find solutions,troubleshooting, and manuals (pdf) files. You must have Adobe Reader 9 to view any file on internet. It's a free download. Hope this helps!
Ryerman
