20 Most Recent Lexmark Color JetPrinter 1100 InkJet Questions & Answers
You likely mean LEXMARK. The printer will function without software other than what is in internal to it (firmware). If you want to print from your computer, you will need the print driver installed.
Lexmark Color... | Answered on Apr 12, 2013
Hi You can download driver from below link. Click here Click on above link then select os and download driver then install. Let me know if you need further assistance. Thanks for using FixYa.
Lexmark Color... | Answered on Aug 30, 2010
Do you have a Lexmark 1100?
Kazaa is a good way to get viruses in your computer. All downloads from Kazaa (or any other sharing program) should be selected and scanned by antivirus software before you do ANYTHING with them. Kazaa bypasses your antivirus.
This seems VERY fishy - do a complete antivirus sweep, NOW.
Lexmark Color... | Answered on Apr 02, 2010
hhmmm...ok..well..here's a suggestion.
A. remove the old printer that you installed from printer menu, through control panel.
B. Get the driver again. Sometimes they get corrupted.
C. Install the driver again.. Unplug printer from computer and power it down.
D. Make sure that the driver installs cleanly.
E. Plug printer in again, no power.
F. Turn Power On. XP should 'see' the printer show up on the window. If this does NOT happen, then the cable is most likely no good.
Let us know how this works for you.
Lexmark Color... | Answered on Nov 30, 2009
You need to make your printer the default. Go to Printers and faxes dialog box and right click your printer then make the default.
Lexmark Color... | Answered on Nov 23, 2009
Delete the printer from the printer and faxes dialog box. Then add printer again. This should work.
Try:
http://admin.utep.edu/Default.aspx?tabid=56
Download the Lexmark drivers here.
Remove your printer from 'printers & faxes'.
Uninstall your printer software from 'add & remove' program.
Disconnect your printer from your computer.
Reboot your computer.
Install the printer software from your download.
Follow the on screen instructions, hook up your printer to your computer.
Lexmark Color... | Answered on Nov 22, 2009
i had just this problem. the lexmark site was rubbish, as was the techs. i could print, but not scan.
i fixed it like this. on the start bar, find the printer, x1100series. there is an option "UNINSTALL". select, and all of the software will go. let the machine go through it's paces, and once complete RESTART. [if you use the control panel, there is a residue left over, which prevents the next step.]
then next step is to install the printer, and hey presto - it worked for me:)
Lexmark Color... | Answered on Jul 22, 2009
Oh...this is really old. Are you still out there???
Lexmark Color... | Answered on Apr 04, 2009
You can download the drivers need to install your printer here http://downloads.lexmark.com/perl/downloads/downloads.cgi
This is the Lexmark site, therefore, the best place to download the software you need for your printer.
Once you get to the downloads page, you will need to select your printer model from the drop down menu. On the next page you will select your operating system. The following page will provide you with a list of drivers. Find the one that's appropriate for your printer and click Download.
Also, it's a really good idea to copy or write the file to a CD. This way, you will be able to use the CD to install the printer in the future.
Hope this helps and thanks for using Fixya.
Please share your experience by rating this solution.
Lexmark Color... | Answered on Mar 29, 2009
Yes, Tyrone, there is a way to download the installation files (or drivers). If you need the software to install your Lexmark printer then follow this link http://downloads.lexmark.com/perl/downloads/downloads.cgi
When you get to the downloads page, select your printer model in the drop down menu. Select your operating system on the following page. The next page that you come to will have a list of drivers. Look here to find the appropriate drivers then click Download. After you download these files, you can run them directly from your computer to install the printer.
It's also a good idea to copy or write the files to a CD. This way, you will have them if you need them in the future.
Have you tried printing without spooling?
Disable the spooling feature to see if this still happens.
Right-click printer then click Properties. On the Advanced tab of the printer Properties windows, Select Print directly to the printer.
Click Apply.
You may notice that printing from an application may be slower; however, the point in doing this is to find out if the spooler is causing the issue by bypassing it completely when printing.
I don't know if you used the CD that comes with the printer or if you downloaded drivers from the Lexmark site but you might want to double check the drivers that you're using with the most current and appropriate drivers for your printer. Also make sure that all cable connections are snug.
Here is the link to download drivers from Lexmark http://downloads.lexmark.com/perl/downloads/downloads.cgi
In this case, the first thing that I would do is re-install the printer.
Delete the printer from your computer then, if you have the installation disk, run the setup program to reinstall the printer and all of its drivers.
If you don't have or don't want to use the installation disk, you can download drivers directly from the manufacturer's Web site here
I could have provided a link directly to the download page if you would have provided the name of your operating system (Windows 2000, XP, Vista, etc). However, it's fairly simple finding your drivers. After you get to the Lexmark Web site you will need to type your printer model (1100 Colorjet) in the text box.
On the next page, you will need to select your operating system.
The following page will provide a link to download the driver files used to install the printer.
Make sure you download the correct drivers for your printer model. Using the incorrect drivers can cause print issues such as this one or cause wierd characters to print instead of letters. This kind of thing can also happen if one of the entries placed in the Windows registry by the printer software has become corrupt.
Download the file and run it to re-install the printer.
Print a test page from the printer itself to rule out any issues with the hardware. (You might also want to download the users guide if you don't know how to print a test page from the printer). If the page comes out blank, you will have to stop here and find out why you can't print directly from the printer (this would be an issue caused by the printer). If not, you can move on to the next step.
Next, print a test page from the operating system to rule out any problems related to hardware.
Start > Printers and Faxes > Right-click printer > Click Properties on the General Tab > Click Print Test Page.
If both test pages print successfully then you should be able to print anything without a problem and can try to print and email or word document to see how it comes out.
If the test page printed from the printer came out okay but this one came out blank, this indicates a software related issue and you would have to troubleshoot further.
I know this sounds like a lot to do, however, all you need to do is download the correct drivers (unless you choose to use the CD that came with it), uninstall then re-install the printer, and print a test page from the printer, one from the computer, then print any random document.
i cant install the printer lexmark can u help me
Lexmark Color... | Answered on Dec 28, 2008
You need to install the driver software form disk before connecting the printer.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, findthe file, double click on the file , then if you get introubles, followthe instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vistaon your model page, that means your model is not Vista compatible.
Lexmark Color... | Answered on Nov 19, 2008
Lexmark Color JetPrinter 1100 InkJet Logo
33 questions posted
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
JetPrinter Lexmark
  • JetPrinter Lexmark
Most Popular Question
find driver install ubuntu
  • Office Equipment & Supplies
