20 Most Recent
Lexmark JetPrinter Z11 InkJet Color Printer Questions & Answers
Printing double print
I doubt if it is the printer at fault. its more like a driver fault. uninstall your lexmark driver and reboot then reinstall it. hopefully that should cure it.
Lexmark...
Answered
on Aug 28, 2011
First line prints okay with
What is the operating system of your computer? Disconnect the printer from your computer. Reboot pc. Unplug and replug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to print again.
Note: The Lexmark Z11 printer only works on Windows XP 32-bit and Windows 2000 (
http://bit.ly/m41dci)
Lexmark...
Answered
on Jun 02, 2011
Lexmark to HP problem
I've never successfully connected a Lexmark USB printer to a Parallel port with an adapter as the adapter doesn't provide bi-directional commP, use a USB powered hub, if the system doesn't have USB, try an USB expansion PCI card
Lexmark...
Answered
on Mar 19, 2010
The alignment both vertical and horizontal are
Title: How to Install/Change the Print Cartridge
Document ID:HO46
Back To Answers
Properties
1000 Color Jetprinter
1100 Color Jetprinter
2030 Color Jetprinter
2050 Color Jetprinter
2070 Color Jetprinter
3000 Color Jetprinter
3200 Color Jetprinter
5000 Color Jetprinter
5700 Color Jetprinter
5770 Photo Jetprinter
7000 Color Jetprinter
7200 Color Jetprinter
Lexmark X63
Lexmark X73
Lexmark X83
Lexmark X84
Lexmark X85
Mac OS 8.6
Mac OS 9.x.x
WinWriter 100
WinWriter 150c
Z11 Color Jetprinter
Z12 Color Jetprinter
Z22 Color Jetprinter
Z25 Color Jetprinter
Z31 Color Jetprinter
Z32 Color Jetprinter
Z34 Color Jetprinter
Z35 Color Jetprinter
Z42 Color Jetprinter
Z45 Color Jetprinter
Z45se Color Jetprinter
Z51 Color Jetprinter
Z52 Color Jetprinter
Z65 Color JetprinterHow to install or change the print cartridge; Microsoft Windows 95; Microsoft Windows Me; Microsoft Windows 3.1x
Solution
Microsoft Windows 95/98/Me:
(Applies to all printers)
- Click Start, Programs, Lexmark Series.
- Click Lexmark Control Panel.
- Click Print Cartridge installation.
- Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
- Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
- Insert the print cartridge into the print cartridge carrier.
- Push the cartridge back until it clicks into place.
- If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
- Click the appropriate Cartridge Installed option in the printer software.
- If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
- On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
- Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
- Click OK.
- Close the front cover of the printer.
Lexmark...
Answered
on Dec 22, 2009
How do I align ink jets?
- Click OK.
Lexmark...
Answered
on Dec 22, 2009
Refilled #4 & #5 Lexmark cartridges and
Refilled cartridges are a pain. The small circuit board on the cartridge is deformed when you place the new cartridge into the printer. After you refill the cartridge, the same circuit board is then deformed again when it is fitted. If any of those deformations do not line up with the original ones, you get issues like this one or you get dropouts in the printed characters. This is because the circuit is no longer touching the pads on the print carriage. You cannot remove these deformations without damaging the cartridge. My advice is purchase a printer which does not have the print head attached to the cartridge, like a canon ip1000. Look for something that has ink tanks rather then a print cartridge, or only use new cartridges in your lexmark.
Lexmark...
Answered
on Dec 12, 2009
Lexmark z11 Vista Compatible?
Looks like I've cracked it [Touches wooden desk]. Need a USB to IEEE 1284 36-pin Parallel Printer Cable, like the one I received today (ordered yesterday from
www.cables2u.co.uk). First, connect it to Z11. Turn on Z11 and boot up Vista PC/laptop. (I run Vista Business on my laptop.) Connect cable to computer. Message appears "Installing device driver software". Click it for status. 'Found New Hardware' box appears. Click 'Locate and install driver software'. A message appears "Error loading LXADSUI.DLL. Specified module could not be found". Click 'OK'. Message appears saying driver software installed successfully. ["Yeah, right ..."] (Have faith, folks!) Now, click Start, then Control Panel and double-click Printers. Right click on Z11 and click on Set As Default Printer. Right click on Z11 again and click on Properties. Check on Ports tab that Port USB is ticked for Z11. On Cartridge Maintenance tab, check right cartridge is showing. If not, click 'Install/Change Cartridge' and follow instructions. Then 'Clean Print Nozzles' and 'Align Cartridges'. Check settings on the other tabs in Properties look OK and try printing a test page! It looks good to me!
Lexmark...
Answered
on Nov 04, 2009
Put in new cartridge and unit will not print.
It may be caused by some issues. Check:
* Did you remove the plastic from the connections from the cartridge as the instructions indicates?
* Is the cartridge connector from the printer ok?
* Is the cartridge correctly installed?
* It's a new cartridge? I mean, NEW. Not refilled one or a cartridge that expired two years ago.
* Try running one or two "Clean printer head" procedure to see if ink flows.
Good luck !
Lexmark...
Answered
on Sep 04, 2009
Triple vertical printing with Z11
Here's what worked for me: (I'm using a black ink cartridge, but my 'printer properties' were set for a color cartridge, thus basically sending a '3-color signal' to my printer; making it print in triple vertical.)
Go to Settings > Control Panel > Printers. Right click on your printer, and click Properties. Click the Cartridge Maintenance tab, then click Install / Change Cartridge. Select the cartridge you are using in the drop-down list, and click Continue. Print an Alignment Page. If this dosen't work, close everything and try it again: I had to do it twice to get mine to work. Hope this helps!
Kerry
Lexmark...
Answered
on Aug 25, 2009
