20 Most Recent Dell Zylux Powered Subwoofer - P/n A425 Questions & Answers
tip
DELL A425 SUBWOFFER PINOUT
CABLE PIN OUT PIN 1 SPEAKER 1 PIN 5 SPEAKER 2 PIN 3 INPUT 1 PIN 4 INPUT 2 PIN 8 EXTERNAL VOLUME CONTROL PIN 2-5-7-9 GRD PIN 8 MUST TO GROUNDED FOR MAXIMUM VOLUME OUTPUT
I need the diagram of parts
wot
5/6/2014 10:08:27 AM • Dell Zylux... • Answered on May 06, 2014
0answers
Ax510pa removal
Be the first to answer 10/10/2013 5:25:13 PM • Dell Zylux... • Posted on Oct 10, 2013Be the first to answer
0answers
Dell a425 disassembly
I found this URL for you that shows a Dell forum where you could probably get all the info you need. It also has specifications for all the internals should you need to replace something. Good luck and be safe. I learned to hate capacitors a long time ago. :-) http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_E876EF53BCA3F058E030030ABD6260B2&isLegacy=true
5/24/2012 7:52:36 AM • Dell Zylux... • Answered on May 24, 2012
2answers
I have Dell speakers, hp tower, I can't get sound out of speakers. Do I plug both the usb plug & speaker plug into tower?
If there is no separate power supply the usb plug must be used in order to provide power for the speakers, but whether the analogue cable must be plugged in or not will depend on the internal construction and specification of the speakers. I suggest you initially use the usb and if there is no sound and no on-screen instructions, plug in the analogue line. If there is a separate power supply the speakers are probably and either/or design.
12/4/2018 4:19:38 AM • Dell Audio... • Answered on Dec 04, 2018
2answers
My Dell P32E just all of a sudden started having static and dragging when playing music and also some static when not playing music. This is my lifeline! How do I fix it?
what is 'dragging'? most likely dirty contact on the plug from computer to the speakers.
10/3/2018 12:02:00 AM • Dell Audio... • Answered on Oct 03, 2018
Hello there..I've got a Dell
Windows has a troubleshooter for the audio system in most computers. Get the "fix" here: https://support.microsoft.com/en-us/help/4026994/windows-fix-sound-problems Good luck!
1/14/2018 6:06:10 AM • Dell Audio... • Answered on Jan 14, 2018
My applications last only as long as I leave my computer on. How can I make them stick?
Is there a battery back up somewhere on your computer? It could have failed. Or at least something connected with it. It could be an electronic fault. Bad capacitors etc. I assume they have ruled out a virus?
11/24/2017 8:07:05 PM • Dell Audio... • Answered on Nov 24, 2017
Background noise recording with dell
Get a wired lapel microphone and plug it into the microphone input on your Dell. The onboard mic is designed to record all ambient sounds. You want a different product to get the result you're looking for.
5/20/2017 2:35:03 AM • Dell Audio... • Answered on May 20, 2017
Altec Lansing ADA 745 speakers.
you need an amplifier
5/6/2017 10:26:40 AM • Dell Audio... • Answered on May 06, 2017
How to take apart a dell mms 5650 subwoofer
funny thing about speakers is that they need an enclosure to work properly in the unit has a back and the car has a door skin or other enclosure to work in
2/5/2017 12:45:30 AM • Dell Audio... • Answered on Feb 05, 2017
Setup Altec Lansing BX1220 speakers usb-powered...green 3.5 in back with usb next to it. I have a windows 10 free upgrade on a rebuild Dell Optiplex 755 vista desktop.
Forget the upgrade to windows 10, Dell doesn't recommend you do this as it disables some programs. I have the same computer.
9/23/2016 7:15:53 PM • Dell Audio... • Answered on Sep 23, 2016
Dell a525 speakers. One side is louder than the other. What can I do to fix this problem?
adjust the balance knob to center position
5/30/2016 5:47:12 AM • Dell Audio... • Answered on May 30, 2016
How do I find driver for my speakers. Disc not available. They stopped working after MS update.
My daughter had the same trouble with her Dell computer. The guy who was reloading Windows found the additional drivers on the Dell website. The Dell recovery disc supplied with a new machine already contain those drivers.
2/23/2016 10:30:26 PM • Dell Audio... • Answered on Feb 23, 2016
How can I fix the sound on my Windows 7 computer
Try plugging a pair of headphones or earbuds or a different pair of known-working speakers (in places of the current speakers) - if you get sound with the "replacements", then there's a problem with the "current" speakers; otherwise, the problem is the sound on the unit. Alternatively, plug the "current" speakers into a different (preferably, known-working) unit. If there's still no sound, then there's a problem with the speakers; otherwise, the problem is the sound on the original unit.
1/5/2016 1:13:42 AM • Dell Audio... • Answered on Jan 05, 2016
I have any Silex 824 Dell computer 2.1 subwoofer system the wires or cut how can I repair them properly
Joseph Nucifora, Unfortunately, Dell does not have any wiring diagrams for speakers or sub-woofers. They would replace them if they are broken and are under warranty. Thank You, Dell-Jesse L Dell Social Media and Communities
10/30/2015 5:44:22 PM • Dell Audio... • Answered on Oct 30, 2015
Dell Zylux Powered Subwoofer - P/n A425 Logo
Popular Tags
9 questions posted
Top Dell Audio Players & Recorders Experts
Jean Sintulaire
Ekse
Mandeep  Singh
Mandeep Singh
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Audio Players & Recorders
Most Popular Question
dell a425 disassembly
  • Audio Players & Recorders
