20 Most Recent
APC Smart-UPS 1000XLI (SUA1000XLI) UPS System Questions & Answers
I have a brand new APC 1000xl I just plugged into
You can push and hold the on button to start a self test. Or you can turn off the UPS. Unplug it from the wall. disconnect the batteries and push the on button to reset the logic. if that wont work return it.
Replace battery
The battery compartment is located on the bottom of the UPS. You can get replacement batteries for your model APC UPS from the APC WEB site.
All led blink
hi, if the leds blinking are for batteries (the ones above the battery symbol) then its not that the machine is not faulty. it needs some calibration constants. contact your local apc service engineer centre. this happens especially after battery change.
When it is switch on, the yellow light comes along
check and replace the battery: 12v/7.2ah(exide is preferable)..
there may b problem with smps dc-relay section or switching section or push-pull section, go through only if u r a professional..
else contact system admin/vendor....
Battery doesn't charge to full
As batts get older they take longer to reach full charge.
There may be a problem with a cell or maybe or a bloc
Batts are made up of sets of cells which make up a bloc.
eg 6 cells = 12 V bloc
Most UPS units have more than 1 bloc inside.
Standard batts can last about 3- 5years, it all depends on use, temp, cost of ups, and type of batt.
Some ups units allow you to check the batts with sofware, 1 other thing you can do is... with the ups powered up and running,do a test by connecting a lamp to the ups and failing the supply, for a short time say 3mins this will test the batts can work on load.
Before you do this make sure your critical load is not powered up.
Hope this helps , let me know by voting, thanks for using FixYa.
No output
bacause is overloaded. There is a reset switch inside the ups, locate that and reset it.
Not working
can you send me information on your ups problem, do you still need help with it?
How to replace an apc battery back up battery
Depend on model.
For 600VA and above
Go to APC site and check model of replacement battery.
Peel open the front plastic panel and unscrew 2 screws of metal panel.
Batteries can be slid out and replacement done when PC is online.
Only two wires to disconnect and connect.
HELP! See details please
I would replace batteries, they do not have a long life.
beeping The Back-UPS product has entered a low battery condition - This alarm indicates that the UPS has reached a Low Battery condition and will soon shutdown. The UPS can only operate on battery for a limited amount of time.
clicking
copy and paste link
https://www.apc.com/us/en/faqs/FA158813/
Where can I get transistor GP4063D/ IR 214 for APC UPS IS1244003099
You can purchase electronic components, such as the GP4063D/IR214 transistor, from various electronic component distributors such as Mouser, Digi-Key, Arrow Electronics, and more. You can also check with local electronics retailers or online marketplaces such as Amazon or eBay. It is best to check the availability of the specific component with multiple suppliers to ensure that you can get the component you need in a timely manner.
APC BK650EI 650 VA 400 Watts (1) IEC 320 C13 (Surge Protection) (3) IEC 320 C13 (Battery Backup) Outlets Back-UPS CS 650 USB/Serial. It blinks random orange LED.
I say yes he manual shows ,setting sensitivity here.
the sound like charger fail. Inside.
inverter works, did you let it charge overnight first.
and disable the beeper if annoying.
is AC line voltage low? that too can beep.
is this USA model 120vac or outside USA>
also if the UPS is for another country that will be bad.
650EI , is not the E means European version"??? why skip country.
>? and matters huge that.
EI is 230vac version, and will be wrong used in 240vac countries and worse.
yellow led only blink is low line AC as the manual tells
my guess you bought the wrong UPS?>
v2 docs but not told version
page 2.
https://download.schneider-electric.com/files?p_Doc_Ref=SPD_AHUG_990-9237_EN&p_enDocType=Quick+start+guide&p_File_Name=BU+UM+990-9237B+MN01+EN.pdf
