20 Most Recent
Lexmark Optra Se 3455 Laser Printer Questions & Answers
MY OPTRA SE 3455 IS
A 921error indicates that the fuser
unit failed to reach the standby temperature.
- If this is the first time you have seen the error, turn the printer off and
on. Leave the printer off for at. least 10 seconds before turning it back on.
This gives the printer's engine board a chance to reset.
- If this is an intermittent error, you may want to check how the printer is
plugged in, even if it has worked on this surge device for months. Make sure
the printer is plugged straight to the wall and not through a surge device or
power strip. Power strips and uninterrupted power supplies can cause a low
amperage problem in your printer which can trigger a false fuser error.
- If this does not help or if this error appears every time the printer is
powered on, you will probably need service on the machine.
If you need further assistance please contact Lexmark Technical Support or any Lexmark authorized service provider.
My se3455 is stuck on
Power of the machine. Press and hold button 2,3 and 5 and power up the machine till the masage reset....... apears.
961 Service Memory Error
The
961 memory error indicates that the memory SIMM in slot 1 is defective or incompatible. Here's an article in the Lexmark website to tell you on what the problem is about and guides you on what to do when having this kind of problem. Just click on this link:
http://bit.ly/aykPBR .
No LCD display
if there is no lcd display then most probably the display has gone bad.you can definitele get it replaced from a local store or from the manufacturer if in warranty.the manufacturers also have some paid repair plans if you are out of warranty.you can contact the respective tech support and get help.
Lexmark quality
Do me a favor, please. Call the Lexmark office in Denmark. The quick exchange of printers is designed to use replacement printers that have been repaired and returned to the system as ETN (Equivalent to new).
However, you purchased a new printer and it has an out of box failure. You are entitled to a brand new replacement printer. The branch office should be able to help you out.
Please let me know if they do not.
Don
PRINTER SHOWS NO PAPER IN DRAWER
There is a sensor that detects paper just after the paper tray. No matter what is the reason that paper doesn't reach the sensor your printer will indicate that there is "no paper".
You should check is something preventing transport system even to reach the level of paper. In the case of Lexmark E342 or E250 printers, for example, two wheels with black rubbers rotating around common axis are pushing the paper . When you pull out the paper tray the transport system with rollers can be seen from the bottom side of the printer. If the rollers are not laying on the surface of the paper they can not push it inside the printer.
If you are sure that it is not the case the next thing you should check is the rubbers mentioned above. They must be clean enough to have efficient traction with paper. You should take the rubbers off the wheels, wash them with water and soap, rinse them and thoroughly dry. Put them back and try.
Good afternoon. My Lexmark 792 printer shows error 956.02 at startup when adjusting colors, how can I solve it?
The 956.02 error on your Lexmark 792 printer indicates a system board issue. Troubleshoot it step by step:
Power off the printer: Turn off the printer and allow it to remain powered off for 10 to 20 seconds before turning it back on.
Check the code level:
You can identify the current code level using either of the following methods:
Method 1: Print the Menu Settings Page:
Touch the Menu button on the printer's operator panel.
Select Reports.
Choose Menu Settings Page to print the page.
Look for the code level under Device Information.
Method 2: Use the Printer's Embedded Web Server (EWS):
Open a web browser (such as Internet Explorer) and enter the printer's IP address.
Click on Reports and then select Device Information.
Download and install the latest firmware:
If your printer's code level matches any of the following:
For C792: LHS1.HC.P129 or LHS1.HC.P130
For X792: LHS1.MR.P131, LHS1.MR.P135, or LHS1.MR.P135a
For X925: LHS1.HK.P136a
Proceed to download and install the latest firmware.
For C792: LHS1.HC.P131 or later
For X792: LHS1.MR.P135b or later
For X925: LHS1.HK.P136b or later
Contact Lexmark Technical Support for service.
Update the firmware:
Download the latest firmware from the Lexmark Support website.
Save the file and extract it to the same directory.
Use the appropriate Authorization Keycode:
For Lexmark C792: c792
For Lexmark X792: x792
For Lexmark X925: x925
Update the firmware using one of the following methods:
Embedded Web Server (EWS): Open a browser, enter the printer's IP address, and select Settings > Update Firmware.
USB utility: Follow the detailed steps for updating via USB flash utility.
USB thumb drive: Refer to the steps for updating using a USB thumb or flash drive.
FTP: Follow the steps for updating via FTP.
If you need further assistance, please contact Lexmark Technical Support. When calling, have your machine/model type and serial number (SN) ready.
956.01 system board error ' Lexmark C792
Error Codes > Lexmark > X792dtse > Code 956.02 (printcopy.info)
What can replace the ibm lexmark wheelwriter 1000
If you're looking for a replacement for the IBM Lexmark Wheelwriter 1000, you might consider a typewriter like the Brother M-1000, the Olivetti Studio 45, or the Smith Corona SR8000. These typewriters have similar features and capabilities to the Lexmark 1000, and they're often considered to be good alternatives.
My computer guy just installed Lexus Mint on my computer and downloaded the proper driver for Pantum 7100 series printer
How do you 'install' Lexus Mint green on your computer?
https://www.google.com/search?q=Lexus+Mint
Driver
PANTUM
https://global.pantum.com > support > download > dri...
Home Service&Support Driver/File Download Driver ... printer. Product Series. Product Name. You may need. Pantum P2500 Windows Driver. Version: V2.6.30.
PANTUM M7100DW Printer Driver Download
trikprinter.com
https://www.trikprinter.com > PANTUM
Apr 8, 2017 - Install Driver For Printer. Install Print Driver For Windows : Download the file. select the location of the file that is already stored. Double ...
Drivers for printers Pantum M6700 / M6800 / M7100 / ...
DriverFresh.com
https://driverfresh.com > DF.com > Printers and MFPs
Drivers for printers Pantum M6700 / M6800 / M7100 / M7200-series for Windows 11 - XP (32/64-bit), Mac OS X 12 - 10.5, Linux Ubuntu 20.04 - 12.04 in English.
how do I publish a printer [duplicate]
Ask Ubuntu
https://askubuntu.com > questions > how-do-i-publish-...
Jan 5, 2013 ยท 1 answer
Open the dash and type Printers, then click on the "Printers" icon. That will open up a window that will probably have a list of printers.
What is CUPS server and how to share a printer ...
Oct 28, 2011
HPLIP or CUPS cannot Find Network Printers?
Jan 25, 2013
More results from askubuntu.com
Deploying Printers to Domain Users and Computers with ...
Windows OS Hub
https://woshub.com > Group Policies
Nov 8, 2022 - You can publish your shared printers in Active Directory. To do this, enable the List in the Directory option in the printer settings on the ...
Use Group Policy settings to control printers
Microsoft Learn
https://learn.microsoft.com > ... > Windows Server
Feb 23, 2023 - Describes the policies specific to managing printers and how to enable or disable printer management by using the Local Group Policy Editor.
Need drivers for Lexmark 4431
- Visit the Lexmark Support Website: Go to the official Lexmark website (www.lexmark.com) and navigate to the "Support" or "Downloads" section.
- Enter Printer Model: In the search or product support area, type "Lexmark 4431" or the full printer model number (e.g., "Lexmark 4431-001") and hit Enter or click the search button.
Lexmark cs 410dn EN E4 16 error
The "E4 16" error message on a Lexmark CS410dn printer indicates that there is a problem with the printer's toner cartridge. This can be caused by a variety of issues, such as:
- The toner cartridge is not properly installed in the printer.
- The toner cartridge is not compatible with the printer.
- The toner cartridge has reached the end of its useful life and needs to be replaced.
- The printer's firmware is out of date and needs to be updated.
To resolve the issue, you should try the following steps:
- Turn off the printer and unplug it from the power outlet.
- Open the printer's front cover and ensure the toner cartridge is properly installed.
- Clean the electrical contacts on the toner cartridge and the printer with a dry, lint-free cloth.
- Reinstall the toner cartridge in the printer, being careful to align it properly.
- Turn on the printer and check if the error message is cleared.
If the error message persists, you may need to check the compatibility of the toner cartridge with your printer model, and the age of the cartridge. If the cartridge is old, you might need to replace it with a new one.
Updating the firmware of the printer can also solve the problem, check the Lexmark website for update on the same.
In case the problem persists after trying all the above troubleshoot, please contact Lexmark support for further assistance.
