20 Most Recent Sigma AF 70-300mm f/4.0-5.6 DL Macro Super Lens for Canon-EOS Questions & Answers
15answers
Err 01 Communication between Camera & Lens is Faulty
cleaning the contacts did nothing for me. what ended up fixing it was turning the camera to AV mode and setting to the highest f value. (f22) and then taking a picture. after that i was able to change it to what ever and resume as normal. hoping i dont see that error again.
5/28/2022 7:54:34 PM • Sigma AF... • Answered on May 28, 2022
I have a Half a year old TAMRON 70-300mm Lens which i have actively used for both macro and normal zoom almost every day since i bought it. For maybe one month ago, when i turned to portrait mode it s
cleaning the contacts on lens and camera is about all you can do. If its faulty and still under warranty then you'll need to send it back to where you got it from, any attempt to fix it yourself will void the warranty.
2/10/2018 3:59:08 AM • Sigma AF... • Answered on Feb 10, 2018
Sigma 70-300 F4-5.6 APO DG MACRO for Nikon AFD Focusing problem
had this lens for my Pentax and used it for more than 10 years without trouble. Have you got the lock on? should be a little button on the side. Has it been dropped, maybe damage to the threads inside. If its still under warranty then take it to the place you bought it from with all its paper work and get it checked out.
2/10/2018 3:54:53 AM • Sigma AF... • Answered on Feb 10, 2018
2answers
I have a Sigma DL Zoom 75-300 mm lens that I would
Simply clean your camera lens contacts
Here is a tutorial , how to clean your camera lens contacts
http://www.youtube.com/watch?v=wUt-K6w7lc0
Good luck and regards
2/10/2015 6:28:01 PM • Sigma AF... • Answered on Feb 10, 2015
I have error 01 on my Quantary 70-300 lens, I have tried to clean it, and different appitures as suggested, however I am still getting error01. Any other suggestions?
If the lens is compatible with your Canon, the only thing I can think of is a defective chip or a bad connection inside the lens. just bring it back to the shop you bought it.
10/14/2014 7:11:41 PM • Sigma AF... • Answered on Oct 14, 2014
How to change resolution of camera?
In the camera menu select 'Quality' RAW will be he highest resolution then Large jpeg, Med jpeg going down to the lowest which is S. Your camera my show the quality in Mps size the highest no. will be the highest resolution
8/6/2014 6:42:12 PM • Sigma AF... • Answered on Aug 06, 2014
Sigma 70-300 dl working on 600d
Have a look here http://www.dpreview.com/forums/thread/3124076
8/6/2014 6:35:26 PM • Sigma AF... • Answered on Aug 06, 2014
How to fix an error 99 on a Sigma 24-70 mm lens
The error 99 on your Canon is the last thing the camera can think of, if it really does not know what is wrong. If you don't have the message when using a different lens, and the error keeps coming back with that lens, you are right it is in the lens. But again the camera can;t find out what. The only thing you can do is make sure the contacts are clean and shiny and nothing os blocking free movement of all the parts on the lens. If you can't get it working correct, please contact a Certified Sigma service centre.
6/8/2014 1:48:38 PM • Sigma AF... • Answered on Jun 08, 2014
2answers
Trouble focusing with sigma 70-300 DL macro super lens
It will not focus on anything closer than 5 feet.
(From Sigma lens literature)
Capable of macro photography, this lens has a 1:2 maximum close-up magnification at the 300 mm focal length. It's the ideal high performance lens for portraits, sports photography, nature photography, and other types of photography that frequently use the telephoto range. It also has a switch for changeover to macro photography at focal lengths between 200mm and 300mm with a maximum close-up magnification from 1:2.9 to 1:2. The minimum focusing distance is 1.5m / 59 in. at all zoom settings.
5/13/2014 12:13:25 PM • Sigma AF... • Answered on May 13, 2014
Canon ds126151
Hi If the canon a digital one if so the sigma 70-300 may be to old and not compatible only if the sigma 70-300 is a super can it be rechiped will need to be sent to sigma
3/30/2014 3:58:02 PM • Sigma AF... • Answered on Mar 30, 2014
DS 126151 error
What kind of error? Err 99? You mention DS 126151, that's the model number. This camera is mostly know as Canon EOS Rebel XTi? Also known as the EOS 400D or EOS Kiss Digital X. If you are getting a Err 99 while shooting, try any other lens that will fit on your Canon. In most cases the aperture will become defect in these lenses. Not worth repairing if you ask me. One thing you could do, is shoot only at its maximum aperture. So that'll be F4.0 at 70mm and F5.6 at 300mm. That might work, but that might not be suitable in every situation.
1/4/2014 3:32:24 PM • Sigma AF... • Answered on Jan 04, 2014
Does Sigma 70-300mm f/4-5.6 DG Macro Telephoto Zoom Lens fit canon eos rebel
Sigma makes their lenses with a variety of camera mounts. If you get the lens with a Canon mount then yes, it will fit any EOS Rebel camera body. A lens with a Pentax mount, for example, will not fit a Canon camera.
11/24/2012 4:22:28 PM • Sigma AF... • Answered on Nov 24, 2012
2answers
When I try to take a picture with my New Canon 450d/Sigma 70-300
check your card,change with new cf.That might fix problem i had the same issue and it was my card.
7/20/2012 9:10:51 PM • Sigma AF... • Answered on Jul 20, 2012
Is it possible to convert a sigma lens to fit a canon body or by using an m42 adapter?
Sigma makes their lenses with a variety of mounts. If the lens has a Canon or M42 mount then there is no problem. If it has a Minolta mount, for example, then replacing the lens will be easier and just as cheap as changing the mount. If it has Nikon mount, you can buy adapters to fit it to Canon or M42 bodies.
5/13/2012 6:45:48 AM • Sigma AF... • Answered on May 13, 2012
Does the Sigma AF 70-300mm f/4.0-5.6 DL Macro Super Lens work on a Canon EOS 600D?
Sigma makes lenses with a variety of mounts. As long as you get one with a Canon mount it will work on your 600D. A lens with, say, a Sony mount, will not work on a Canon camera.
5/2/2012 4:44:38 PM • Sigma AF... • Answered on May 02, 2012
Are older Sigma Quantaray lenses
Yes. Bear in mind that many Canon digital SLRs have a sensor smaller than a frame of 35mm film. This results in the image being cropped, narrowing the field of view and making the lens behave as if it was of a longer focal length.
9/2/2011 8:49:44 PM • Sigma AF... • Answered on Sep 02, 2011
Does a "Sigma APO DG
It will fit, but you cannot guarantee that it will be fully compatible.
Third party lens manufacturers have to reverse engineer the patented technology of SLR manufacturers and then arrive at their own alternative and non-infringing solutions. As a result, their lenses are only ever guaranteed compatible with the SLR models available at the time they were manufactured, and if those cameras subsequently have firmware updates then all bets are off.
Sigma do offer an update service on many of their lenses, but it's not free and the lens has to go back to them for modifications.
The only lenses you can be sure of being compatible are the original Canon branded models.
7/14/2011 11:39:32 AM • Sigma AF... • Answered on Jul 14, 2011
Just bought this lens and the MACRO button
You need to zoom past 200mm and then switch it to the macro setting. You will see a mark on the focus ring that you must put the ring past on coming out of macro
7/11/2011 1:11:23 PM • Sigma AF... • Answered on Jul 11, 2011
Instruction Manual. I am looking for a
Hi I sent a email
7/10/2011 9:12:37 PM • Sigma AF... • Answered on Jul 10, 2011
Will a Sigma 70-300mm 1:4-5.6
NO canon fit lens fits a canon only you will need a sigma 70 300 for pentax
7/10/2011 8:43:19 PM • Sigma AF... • Answered on Jul 10, 2011
Sigma AF 70-300mm f/4.0-5.6 DL Macro Super Lens for Canon-EOS Logo
86 questions posted
Top Sigma Cameras Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sigma Camera Expert? Answer questions, earn points and help others
View Most Popular
Sigma Cameras
  • Sigma Cameras
Most Popular Question
fix error 99 sigma 24 70 mm lens
  • Cameras
