20 Most Recent Lexmark X5250 All-In-One InkJet Printer Questions & Answers
Lexmark's site only has drivers to Windows Vista. I found a site that SAYS they have a driver package that works thru Windows 8.1. If that is the case, it will probably work for Windows 10. To protect you, I downloaded the file from the site and Virus checked it. It is clean. Choose 32 or 64 bit. The file IS an .EXE self-extracting ZIP file. extracted the files and they are from Lexmark. I don't have your device, sol I can't verify that it IS for Windows 8 or that it will work for Windows 10. All I can say is try it and see what happens. Here is the link. Good luck!
Lexmark X5250 All In One Driver Download
Lexmark X5250... | Answered on Oct 28, 2015
Hi, Lexmark printer drivers can be found on this site: Driver Update Software for XP Vista 7 8. Have a nice day
Thomas
Lexmark X5250... | Answered on Jan 05, 2015
You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Lexmark X5250... | Answered on May 23, 2012
It sounds like a scanner hardware problem. Please contact Lexmark Technical Support Center for assistance.
Lexmark X5250... | Answered on Mar 28, 2012
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 5200 Series folder.
  4. Select Lexmark Solution Center / All-In-One Center
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Lexmark X5250... | Answered on Feb 10, 2012
Please visit the Lexmark website at http://bit.ly/e8EeXn to download and your model's printer driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Lexmark X5250... | Answered on Dec 26, 2011
The paper goes into the automatic sheet feeder on the back of the printer. Please refer to the Lexmark X5250 User's Guide for a more comprehensive instructions on how to use the printer's features and functions.
I hope this helps.
Lexmark X5250... | Answered on Nov 29, 2011
Please visit the Lexmark website to download and install the Lexmark X5250 printer driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
I hope this helps.
I am going to tell you what i experienced with this type of issue and maybe you can take this and use this information. Two issues
1: cable
2. printer controller module
what is happending is the computer is not detecting the pritner because one of the two events I listed above (VERY COMMON WITH LEXMARK)
If you look at my name below it i wear a lexmark badge. Why>? Because I have helped a ton of people with there Lexmark issues.
check you cable and if that does not work try and diffrent computer or port if all else fails you got a big huge brick for a printer.
Thanks please do be considerate and rate your solution before you leave.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Lexmark X5250... | Answered on Nov 03, 2011
Lexmark X5250 All-In-One InkJet Printer Logo
165 questions posted
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
please looking driver win 10 thanks
  • Office Equipment & Supplies
