20 Most Recent Sony Great Dav-bc150 5-disc Cd/dvd Receiver / S-master Digital Amplifier Questions & Answers
My audio in jack isnt working
you should get the audio in jack replaced with a new one. but before that you should try checking the same with another cord
3/17/2014 10:01:12 AM • Sony Great... • Answered on Mar 17, 2014
3answers
Connecting SONY TA-D505 amplifier LBT-D505
Hi David, do you want to connect the ST-D505 tuner to the TA-D505 amplifier? You just have to connect an audio cable of two RCA (red and white) from the audio output L and R of the tuner ST-D505 to the input of Tuner in the amplifier TA-D505 Remember to connect the FM antennas and the AM Antenna Loop on the ST-D505 tuner To listen to it, you have to select Tuner on the TA-D505 and enjoy the favorite radio stations I hope you have my comments Greetings Franco Dosil Hola David, quieres conectar el sintonizador ST-D505 al amplificador TA-D505? Simplemente tienes que conectar un cable de audio de dos RCA(rojo y blanco) desde la salida de audio L y R del sintonizador ST-D505 a la entrada de Tuner en el amplificador TA-D505 Recuerda conectar las antenas de FM y la Loop Antena de AM en el sintonizador ST-D505 Para poder escucharlo, tienes que seleccionar Tuner en el TA-D505 y disfrutaras de las estaciones de radio preferidas Espero que te sirvan mis comentarios Saludos Franco Dosil https://elektrotanya.com/sony_lbt-d505_d505cd_d505cdm_d505m.pdf/download.html
4/22/2024 2:47:35 PM • Sony Audio... • Answered 2 days ago
The display does not work on my Sony CDP-CE375 CD Player.
troubleshoot the issue: Reset the CD Changer: Turn off the CD player. Press the CLEAR button. Simultaneously, press and hold down the POWER button on the CD player for 60 seconds. If this doesn't resolve the issue, proceed to the next step. Check for Error Messages: If you encounter difficulty playing a disc and receive any of the following error messages, there may be an incorrect setting or a problem with the disc: NO DISC DISC ERROR CD ERROR TOC ERROR Refer to the instructions supplied with your CD player to verify model-specific information and troubleshoot the issue. Internal Component Repair: If the display issue persists, it might be related to an internal component that requires repair.
4/21/2024 5:40:21 PM • Sony Audio... • Answered 3 days ago
My Sony model # MHC-V11 MAKES NO SOUND everything seems to operate but i cant get no sound from it
Troubleshoot this issue. Here are some steps you can follow: Check Speaker Connections: Ensure that the rear surround speakers are properly connected to the Audio/Video (A/V) receiver. If applicable to your model, verify that the A/B speaker selector is set correctly. If the speakers are connected to the A speaker connection, the selector must be set to the A position. Test Tone Operation: Perform a test tone operation to check if the speakers are functioning correctly. Increase the rear speaker volume or adjust the surround speaker settings to the maximum level. Speaker Size Settings: Try selecting a different size (small or large) for the rear surround speakers in the menu. Surround Sound Mode: Verify that the A/V receiver is set to a surround sound mode. For Dolby ProLogic surround sound, ensure that the center-channel mode is set to NORMAL or WIDE. If your source is a DVD or Blu-ray Disc player, check that surround sound is enabled in the player's menu. The audio being received must be multi-channel. Different Surround Sound Mode: Try setting the A/V receiver to a different surround sound mode. Source Content: Verify that the source you are playing is encoded in surround sound. Note that during periods of mainly dialog, most of the sound may come from the center speaker only, with audio coming out of the rear speakers when there is background or ambient noise. Factory Reset: Reset the unit back to factory default settings (consult your operating instructions for model-specific steps). If applicable, follow the steps for calibrating the appropriate settings automatically after connecting the calibration microphone device. Speaker Wires and Replacement: Check and replace the speaker wires if necessary. Consider connecting a different pair of speakers to see if the issue persists. If you've tried these steps and the problem remains unresolved, I recommend seeking professional service.
4/21/2024 5:35:41 PM • Sony Audio... • Answered 3 days ago
2answers
My Sony DHC-FLX7D and DHC-FLX5D is not working due to humidity. Is it possible to repair it ?
steps to troubleshoot and potentially repair them: Troubleshooting Low Sound or No Audio from Rear Surround Sound Speakers: If you're facing audio problems, especially with the rear surround sound speakers, consider checking the following: Ensure that all speaker connections are secure and properly plugged in. Verify that the speaker wires are not damaged or frayed. Check the speaker settings in the system menu to ensure correct configuration. Inspect the speaker impedance and compatibility with the system. If you're using wireless speakers, check their power supply and connectivity. Refer to the operating instructions manual for specific troubleshooting steps. Flexible Circuit Board Repairing: If the issue is related to internal components, you might need professional repair. However, if you're comfortable with electronics, consider these precautions: Keep the soldering iron temperature around 270°C during repairs. Avoid touching the soldering iron on the same conductor of the circuit board more than three times. Be gentle when soldering or unsoldering to prevent damage to the conductor. Important Notice: To prevent fire or shock hazard, avoid exposing the unit to rain or moisture. Do not open the cabinet; refer servicing to qualified personnel. Avoid installing the appliance in confined spaces like bookcases or built-in cabinets.
4/21/2024 5:33:26 PM • Sony Audio... • Answered 3 days ago
How do I preset a second AM station on a Sony SRF-M97 Walkman
It looks like the manual knows, and you can have 5 AM station presets and 15 FM. https://www.google.com/search?q=preset+a+second+AM+station+on+a+Sony+SRF-M97+Walkman ..
4/18/2024 5:09:49 AM • Sony Audio... • Answered on Apr 18, 2024
Sony PS-FL7 direct drive turntable. When start button is pressed it illuminates but turntable won't rotate. All other functions work as they should.
'Direct Drive' appears to mean something different to Sony unless the belt is for another function. https://lptunes.com/products/sony-ps-fl7-ii-ps-fl7-ii-psfl7-ii-turntable-tonearm-belt-replacement Service Manual
Sony PS-FL7 Stereo Turntable System Manual
Vinyl Engine https://www.vinylengine.com > library > sony > ps-fl7 Sony PS-FL7 owners manual, service manuals and schematics are for reference only and the Vinyl Engine bears no responsibility for errors or other inaccuracies. "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(56px);"> Rating: 8/10 · ‎ 4 reviews
SONY PS-FL7 service manuals download
NoDevice https://www.nodevice.com > ... > Vinyl Players > SONY SONY PS-FL7 service manual (Vinyl Players) in PDF format will help to repair SONY PS-FL7, find errors and restore the device's functionality. ..
4/6/2024 7:54:41 PM • Sony Audio... • Answered on Apr 06, 2024
My sony icf-cl75ip wont turn on and is making a clicking sound. How can I fix this?
There is not reason this would click and not turn on. If it just clicked, it would likely be caused by interference from another appliance, typically a fridge or freezer. The most likely reason is a relay in the internal power supply. It will need a Sony Service Centre. https://www.sony.com/electronics/support/res/manuals/4154/41545841M.pdf It isn't a recorded known issue. Sony are high quality equipment so it is worth getting it fixed. https://www.google.com/search?q=sony+icf-cl75ip+clicks+and+not+working ..
4/6/2024 2:59:06 AM • Sony Audio... • Answered on Apr 06, 2024
Hello Sir. My Sony Deck MHC RV-900D Stereo, it's front panel is not working. I changed the fuse, replaced it but after no response. Please Help me Sir, Thanks.
Open it up and look for bulging or split electrolytic capacitors, especially in the back to the display and the power supply. Or take to an electronics technician for diagnosis. https://www.google.com/search?q=Sony+deck+MHC+RV900D+not+working ..
4/3/2024 2:34:25 AM • Sony Audio... • Answered on Apr 03, 2024
Sony Music system error code display c81, what is minig
C81 error indicates an internal hardware fault.Check CD mechanism is not jammed.
3/3/2024 7:36:52 AM • Sony Audio... • Answered on Mar 03, 2024
Sony Audio Rack SU-S5520. Need a power cord for it please?
Question edited for clarity, turned around plus CAPS. It should be a standard figure 8 connector. https://www.google.com/search?q=sony+audio+rack+su-s5520+power+cord+replacement ..
3/1/2024 8:31:36 PM • Sony Audio... • Answered on Mar 01, 2024
I need code for Sony MHC VX33 sound IC
STK402, IC501. Part number 8-749-016-96
2/23/2024 6:13:11 PM • Sony Audio... • Answered on Feb 23, 2024
Sony mhc-gnz888d is on standby and wont power on
Standby problem solved
2/19/2024 4:08:20 PM • Sony Audio... • Answered on Feb 19, 2024
Why is my Sony DZ- 840K Home Theater displaying "Please Wait" like for ever, without loading to play anything. Please I need an urgent remedy to this problem.
You realize we are Fixya dot com and we aren't Sony Support? We don't do 'urgent remedies' although we do try to help for free. https://www.google.com/search?q=Sony+DZ-+840K+Home+Theater+displaying+%22Please+Wait%22 I wrote this Fixya Tip which you can try first. https://www.fixya.com/support/r29927004-dvd_player_or_cd_player_not_reading ..
2/9/2024 5:57:26 AM • Sony Audio... • Answered on Feb 09, 2024
I have a Sony stereo system PS-LX47P. The turntable has stopped working, I have changed the belt,but still not working. Can any Sony turntable be used to replace it?
The record deck is known as a PS-LK47P. If you wish, another deck will work as long as it has a magnetic cartridge and no preamp built in. A Technics SL-1200 is the sort that is fine and a definate upgrade.
1/30/2024 7:38:29 PM • Sony Audio... • Answered on Jan 30, 2024
Sony Great Dav-bc150 5-disc Cd/dvd Receiver / S-master Digital Amplifier Logo
8 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
hook up sony s master home theater
  • Audio Players & Recorders
