20 Most Recent Acer Aspire 5733-6607 Intel Core I3-370M 2.4GHz 4Gb 500Gb DVD/-Rw 15 Questions & Answers
try tweaking.com , windows repair it may take some time
Acer Aspire... | Answered on Apr 12, 2017
The FBI "virus" is one of the most malicios malwares around, because it actually encrypts tour data files to blackmail you and they say, you may never get the decryption code, even if you pay.
Actually there are several version of this scam procedure and you should try to identify which one got in your computer, to neutralize and if possible, to get rid of it's effects.
Read some of these tutorials and may find more information doing a google search fror
Remove FBI virus..
3 Easy Ways to remove the FBI MoneyPak virus
Removing FBI Moneypak Interpol Mandiant Cyber Security virus from your...
How to remove FBI virus Removal Guide Malware Removal Software Tutorials
Remove FBI Fine Moneypak Virus Ransomware In 3 Easy Steps Narrated...
Acer Aspire... | Answered on Aug 18, 2016
Sounds like the screen is failing then. The screens are typically between $40-120 and you should be able to find one on amazon.com
I would consider this a medium difficulty repair.
Here is a link to a youtube video detailing the procedure.
Laptop screen replacement How to replace laptop screen Acer Aspire 5733...
Acer Aspire... | Answered on Apr 06, 2015
What graphics card do you have ? (Model). According to that specific laptop specs it is fitted with a Intel graphics adapter and not nvidia so the nvidia drivers will state that there is no supported device found because there is a Intel on-board adapter. I don't think nfs Rivals will work with that on-board Intel graphics adapter sorry.
Acer Aspire... | Answered on Apr 24, 2014
Try re-installing the keyboard driver
Acer Aspire... | Answered on Apr 23, 2014
press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
you might have to many programs trying to or accessing your computer or the internet at the same time or a virus
scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be jamming up your computer
also under processes see what is ticking over in the background again if you see something you
dont need to be running select end now and users you will see who is using your computer
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
you might need to add more computer ram
if you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules.
when purchasing any ram you should always ask if they can guarantee compatibility first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
hope this helps
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have a virus also select
or you might need to add more computer ram
hope this helps
you might have to put more RAM in random access memory to check how much ram you have click start right click on my computer select properties you will see all information about your computer including installed ram
you might have to many programs when you are running your games scroll to bottom of screen (task bar) select task manager applications you will see whats running if you see anything you
dont need running select end now also under processes you might have a virus slowing you down and users you will see who is using your computer
hope this helps
scroll to bottom toolbar bottom of screen right click select task manager
applications you will see whats running you might have a virus if you see anything you dont need
also under processes see what is ticking over again if you see something you don't need to be
running end now
hope this helps
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Acer Aspire... | Answered on Oct 16, 2012
Check to see if there are any keys stuck/depressed.
If so, use a paperclip and fit it underneath the key and gently pry the end that is stuck.
Make sure the laptop is off before attempting this.
Observe where the boot process ends and starts over.
In most cases, this will give an indication where the problem occurs.
If the laptop reboots early on in the process, for example when it is detecting the hard drive, chances are good it is a hardware issue.
If the reboot occurs further along in the process, like when it is loading operating system files, there may be an issue with operating system software.
Test all power and data leads that attach to your hard drive SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as faulty fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
if your computer runs long enough scroll to bottom toolbar (bottom of screen) right click select task manager
some unnecessary programs that could be running your computer over its limits causing memory dumps
also under processes see what is ticking over in the background you might have a virus again if you see something you
dont need to be and users you will see who is using your computer
Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line
you should always ask for a guarantee on the compatibility of the ram before making any purchase
might be getting hot
hope this helps
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver xp
click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: webcam name webcam driver you might have to try a few times to get it right
software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
this will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you
want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
Some webcams and programs require additional software, although that should be installed with the webcam if things are right.
But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date.
But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing.
Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
Go to Facebook and log into your account.
Click the "Profile" tab.
Click the "Video" link in the "Status" menu.
Select the "Record a Video" option. For privacy reasons, Facebook requests permission to access your webcam and microphone.
Check the box next to "Allow" and click "Close."
You will appear in real time on the Facebook webcam window.
Position yourself in front of the webcam and click the red "Record" button to begin recording your new video. When you're finished, press the "Stop" button.
Click the "Play" button to view your video.
If you want to post it on your profile, add a brief message and click "Share."
If you're not satisfied with the outcome, press "Reset" and record a new video.
Video Message
Log into your Facebook account
Navigate through your friends list and select the friend you want to send a video message to on Facebook.
Click the "Send Message" link in the upper-right corner of your friend's page.
Click the "Video" icon in the attachments section at the bottom of the "New Message" window.
Check the box next to "Allow" to give Facebook permission to access your webcam and microphone, and then click "Close."
Press "Record" and record your new video message. Click "Stop" when you're finished recording. When you're finished recording, you can press "Play" to preview your video.
hope this helps
Acer Aspire... | Answered on Oct 08, 2012
I believe you mean the up arrow with the down/right/left all together? It's a common problem and here's a popular program used to remap keyboard keys in order to act like other keys. http://www.randyrants.com/sharpkeys/
Acer Aspire... | Answered on Aug 06, 2012
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
it will prompt you to enter the new password
enter the new password and the password is changed
hope this helps
Acer Aspire... | Answered on Jul 13, 2012
Download the music you wish to burn to your Music folder on your PC.
Then, follow the instructions at this link to burn it to a CD.
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/howto/burn_how_to.aspx
Acer Computers &... | Answered 10 hours ago
go into device manager and delete the drivers, it may ask you if you want to delete the drivers folder, do this as well. then reboot the laptop after its done. when it boots up. check the drive. and in device manager. then install the update. if has windows on drivers installed.
Acer Computers &... | Answered 2 days ago
As it is freezing so soon after switch on - it isn't even trying to boot, a disc is unlikely to be much help because there is a chance your hard drive died.
I would remove the drive and use one of the inexpensive usb/hard drive adaptors with another computer to check the drive before doing anything else.
If the drive is ok either the Windows is seriously corrupted or the laptop has a hardware problem.
I never bother trying to repair Windows but back up what I want to save and format the drive and reload Windows and the other software. It is a lengthy job but it is the best way to clean the drive...
Acer Computers &... | Answered on Mar 24, 2020
If you are trying to use Windows Media Player it's no wonder you can't watch them or you are having codec problems. Open up internet explorer and go to google. In the google search box type in "Download VLC Player". Look at the search results and look for www.videolan.org/vlc to download the player. VLC is free open source and it is a much better player with all the drivers and codec. It runs things that windows media player has a problem playing. Once you download and install it, go to the movie file you downloaded and Right Click on it and select the Open With option. If you don't see VLC listed in the Open With options, choose the option at the bottom that says Choose Program. Look for VLC in the program list. Choose VLC to play the movie and see what happens.
it may have went bad, see if it plays other disks or certin ones
Acer Computers &... | Answered on Mar 14, 2020
According to all my research, your computer does NOT have a blue-ray capable DVD drive. You cannot watch blue-ray movies on it.
Acer Computers &... | Answered on Mar 13, 2020
The standard specs for all of the 5536 models show equipped with a Super-Multi drive which capable of many CD and DVD formats including double layer DVD. However, I don't see support for Blu-Ray.
You could add an external Blu-Ray that connects to USB or FireWire (1394).
http://www.codecguide.com/download_kl.htm
Download and install K-lite. It is a "pack" of all popular codecs. After you install it, your media software will load with the appropriate codec the next time you watch a movie. Enjoy.
Acer Computers &... | Answered on Mar 10, 2020
you can try to play .dat format via windows media player classic. It will be play all format including .vob
Acer Computers &... | Answered on Mar 09, 2020
Acer Aspire 5733-6607 Intel Core I3-370M 2.4GHz 4Gb 500Gb DVD/-Rw 15 Logo
21 questions posted
Ekse
Steve Sweetleaf
Steve Sweetleaf
Gustavo Ortiz
Gustavo Ortiz
View Most Popular
  • Acer Computers & Internet
Most Popular Question
acer aspire 5733 6607 computer unable
  • Computers & Internet
