20 Most Recent Polaroid 7-in. Internet Tablet - Other Questions & Answers
2answers
Can you reset the tablet?
You can reset your Android phone or tablet normally from its Settings screen. Tap the Backup & reset option on the latest versions of Android or tap Privacy if you're using Android 2.3. Tap the Factory data reset option and to through the reset of the steps to confirm the Help on writing a college scholarship essay factory 1 Scholarship Admission Essay Writing Expert Regina Canada
8/30/2018 1:28:23 PM • Polaroid 7-in.... • Answered on Aug 30, 2018
Forcd Factory Reset
best learn the principles of your tablet first first when a battery is less than 10% it takes up to 5 hours to recharge not 5 minutes next many tablets do not recharge when in operation so you have to shut down to allow the recharge to work because the battery was dead flat , of course it will reset as that is the same as removing or installing a new battery
11/11/2017 11:17:33 PM • Polaroid 7-in.... • Answered on Nov 11, 2017
How do i set my tablet to auto save to my SD card
There are several methods to help you set download application path to SD card by default. Please follow the steps given below, Method 1: - Insert the SD card into the device, Touch 'File Browser' on 'Home screen'. - Tap 'Apps', On Apps, select the 'App to be installed'. - Tap OK to install the App to SD card. Method 2: - Tap 'Settings' on 'Home screen'. - Tap 'Storage', Check to turn on SD card, and set 'SD card' as the default storage place. Method 3: - On your Android tablet or phone, tap the 'App drawer' icon from the home screen. - From the displayed list, tap on the 'My files' icon. - From the opened window, on the top right corner, tap the icon with four horizontal lines. - From the displayed menu, tap the 'Settings' option. - On the opened Settings window, under 'Select directories' on the left, tap the 'Set home directory' option. - From the window that appears next, tap to select the desired folder or the entire external SD card where you want the files to be downloaded by default. - Tap the Done button from the top right corner of the window when you are done. GuruAid.com
7/22/2016 9:51:38 AM • Polaroid 7-in.... • Answered on Jul 22, 2016
Need a manual for Polaroid S7BK S7 7-inch dual camera internet tablet
The Polaroid Tablet manuals are available here: http://www.southerntelecom.com/polaroidsupport_tablets.html . Scroll down the list to the S7. The direct link to the S7 tablets is currently: http://www.southerntelecom.com/polaroidsupport/downloads/S7.pdf . (The final two letters indicate the color of the tablet.) This is the only manual available, as far as I know. I hope this helps. Cindy Wells
5/2/2016 10:00:43 PM • Polaroid 7-in.... • Answered on May 02, 2016
THE tablet will not unlock?
If there is no movement when you try to swipe to unlock it then your digitizer(the glass that senses touch and is separate from the LCD) has either been bumped and the ribbon cables that attach to the board could have come loose or the unit has gotten wet and shorted out the board. If you CAN move to the unlock but it doesn't then try re-starting the tablet by holding the power button down for 10 seconds. Wait about a minute then turn it back on and see if it has corrected itself. Apps running in the background can cause this to happen. Hope this helps.
3/31/2016 5:11:59 PM • Polaroid 7-in.... • Answered on Mar 31, 2016
How do I fix a cracked in the inside tablet 9inch polaroid? or where can I take it to here in brisbane Australia
replace the digitizer . http://brisbanecomputersolutions.com.au/tablet-repairs/ if you dropped it and cracked the digitizer the warranty most likely does not cover this damage
11/17/2015 8:27:21 AM • Polaroid 7-in.... • Answered on Nov 17, 2015
I factory reset my andriod polaroid,now its not turning back on. what can i do to fix it/
with most android devices you can hold power and either volume up or down to boot them to a diagnostic screen or the download screen I had to do this with my Galaxy S3 and it saved me having to buy a special dongle to get it to boot to the download screen if you can get it to either one skip any steps and just restart it
11/5/2015 7:19:24 AM • Polaroid 7-in.... • Answered on Nov 05, 2015
Dropped tablet, screen is rainbow
How can I get my Polaroid S8 to connect to a WEP encryption wifi router without changing the router security?
10/15/2015 4:31:08 PM • Polaroid 7-in.... • Answered on Oct 15, 2015
How do I find the tech support group I spoke with last nite about my daughters tablet
Take it to a place that works on tablets like yours, local search for tablet repair. if nothing mail it for repairs.
7/7/2015 12:08:48 PM • Polaroid 7-in.... • Answered on Jul 07, 2015
Polaroid 7-in. Internet Tablet - Other Logo
264 questions posted
Top Polaroid Tablets & eReaders Experts
nexrad_chris
WTF Chuck.....
WTF Chuck.....
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Tablets & eReaders
Most Popular Question
  • Tablets & eReaders
