20 Most Recent
Logitech Cordless MX Duo 967300-0403 Keyboard Questions & Answers
Re15.2
So, I know these questions are ancient. But I've found the cause of this behaviour in my Cordless MX Duo Keyboard.
This behaviour seems to happen when the batteries in the keyboard move around too much. When shaking the keyboard I get this exact behaviour where it spams "r15.2" with a bunch of other random letters aswell.
The solution would be to secure the batteries firmly. Although I haven't been able to do so yet.
2/23/2019 1:35:58 AM •
Logitech...
Answered
on Feb 23, 2019
Cordless MX DUO charger
try removing the batteries from the mouse and place it in the cradle. If the light lights up or flashes, there can't be a problem with the base station contacts. I have the same problem, but I think the problem is inside the mouse.
2/3/2009 11:47:05 PM •
Logitech...
Answered
on Feb 03, 2009
Keyboard problems
confime if the game is pirated or not. If it is then donot use it any more. If it was a free down load then,it should have finished with its life and may harm your system so discard the game.If it is licenced version of the game then approach the company for assistance and upgradation / advice.
2/2/2009 8:57:32 PM •
Logitech...
Answered
on Feb 02, 2009
Keyboard doesint type
Normal
0
Press the Receiver button (and the lights will start
flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT
button on the back of the board to connect the keyboard to the
receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button
on the back of the mouse to connect to the receiver. Then they
should work okay.
Hope this helps. Bud
1/20/2009 8:52:10 PM •
Logitech...
Answered
on Jan 20, 2009
Keyboard does not respond
open your iTouch configuration dialog box, cordless
tab, press connect, press connect button under keyboard.
should work. i have to do that every time i boot up...don't
know why...
6/1/2008 9:03:33 AM •
Logitech...
Answered
on Jun 01, 2008
Frozen keyboard again
First, change the batteries on both the mouse and keyboard. Reset the connections. Reboot. You should be okay.
2/1/2008 10:56:26 PM •
Logitech...
Answered
on Feb 01, 2008
How do I add format to my logitech 650I downloaded from my old logitech to my new logitech and it doesn't have the format button on it
It sounds like you are trying to use the same formatting settings on your new Logitech keyboard that you had on your old Logitech keyboard, but the formatting button is not present on the new keyboard.
To add the formatting button to your new Logitech keyboard, you will need to do the following:
- Open the Logitech Options software. This software allows you to customize the settings and functionality of your Logitech keyboard.
- Select the "Buttons" tab. This will allow you to customize the buttons on your keyboard.
- Find the formatting button that you want to add. Depending on the model of your keyboard, you may have the option to add a variety of formatting buttons, such as bold, italic, and underline.
- Assign a function to the button. To add the formatting button to your keyboard, you will need to assign a function to it. Click on the button and then select the formatting function that you want to use.
- Save the changes. Once you have added the formatting button and assigned a function to it, click the "Apply" button to save the changes.
I hope this helps! Let me know if you have any other questions.
1/2/2023 12:12:25 AM •
Logitech...
Answered
on Jan 02, 2023
Simple bluetooth support for logitech keyboard Y-raj56a?
Unfortunately, Logitech does not offer any Bluetooth support for the Logitech Y-RAJ56A keyboard. The keyboard is designed to be used with a wired connection, and it does not have any Bluetooth capabilities.
Yes, you can use a Bluetooth adapter to connect your Logitech Y-RAJ56A keyboard to a Bluetooth enabled device. However, you should bear in mind that the keyboard will not have any additional features or support when connected via Bluetooth.
So you will need to purchase a Bluetooth adapter. The Kinivo BTD-400 Bluetooth 4.0 USB Adapter is a good choice and is compatible with most versions of Windows and Mac.
P.S.
BTD400 Advisory
A recent update to Windows is preventing the BTD-400 from locating drivers automatically when plugged in for the first time. Please visit the article below to set up the BTD-400 Bluetooth Adapter for the first time.
BTD400 Driver Installation
12/31/2022 12:10:44 PM •
Logitech...
Answered
on Dec 31, 2022
