20 Most Recent
Avaya Partner ACS 308EC (108463001) Expansion Module Questions & Answers
Reset acs 308ec to factory settings
Im assuming you mean an ACS 308 processor not the 308ec expansion module. From a display phone at either extension 10 or 11 press feature 00 - left intercom button twice - #98925327
Page port testing
I am not sure what #617 is but the loudspeaker paging access code on the Partner ACS is intercom 70. If no audio is heard from the paging port on a test set when this is dialed then the paging port is defective. There is no programming necessary to enable or disable the loudspeaker paging access code.
Two extension phones won't ring but all other
Power the carrier off. Pollow the power cord on the right side of the 5 slot carried. There will be a pull switch or a rocker switch. turn off.
Once power out, remove bad module, there is a tab on the top OR bottom depending on the age of your carrier. Pull card away from wall, and insert new card.
Power system back up.
We have 3 units the one with extentions 1 -17 has
The one with extensions 1-17 is the processor. It is possible the processor took a power hit.
To find out what release it is, on a display phone, press feature 59.
It will display:
Partner ACS R......Let us know
Partner phone system
You need to reprogram the voicemail group.
#505, group 7 and enter the extensions where your voicemail is.
www.telemanuals.com
