20 Most Recent Toshiba REGZA 40" 40AV700 FULL HD LCD MULTISYSTEM TV FOR 110-220 VOLTS Questions & Answers
Toshiba Dual Media Player. Error code L3 when trying to open DVD drawer.
Question edited for clarity. Question moved from 'Dual Televisions'. 'make model (what it is)', first 3 words in all questions please' Nothing on L3 except for the Toshiba Copier. Try Toshiba Support direct. https://www.google.com/search?q=Toshiba+Dual+Media+Player.+Error+code+L3 ..
4/14/2024 9:40:04 PM • Toshiba Audio... • Answered on Apr 14, 2024
Toshiba 32LV67U audio receiver code.
:It is possible that your TV is not compatible with the Xbox, or that you may need to enter a specific code. I suggest checking the manual for your TV to try and find the audio receiver code, as well as searching online to see if there are any additional instructions on how to connect it to the Xbox. Additionally, you may want to contact the manufacturer of your TV or Microsoft for further assistance.
1/29/2023 11:19:21 PM • Toshiba Audio... • Answered on Jan 29, 2023
My Right earbud on my Toshiba RZE-BT800E sound great but the right earbud cuts out then comes back on and it is often enought that it drives me crazy. Any suggestions?
try another set if $1 earbuds from the dollar store. have 2 sets so when the wires fails, bingo a fix.
8/20/2022 12:28:06 PM • Toshiba Audio... • Answered on Aug 20, 2022
2answers
I have a Toshiba Laptop
Most laptops do have Microphones built in. I do not know for definate that your laptop does, but you can easily test it to find out.
1. Go to the volume control (double click the speaker icon near the clock on the taskbar), go to recording properties and select microphone as the recording source and set the slider to about 80%.
2. Bring up microsoft sound recorder (its in the start menu somewhere) and click record... when you speak you should see a voice print appear in the sound recorder window.
If you do not see a voiceprint, then you probably dont have a built in microphone, but if you do see a voiceprint as you speak then you do have a microphone built in and you can record into your powerpoint shows to your hearts content.
Hope this helps!
1/7/2022 2:51:58 AM • Toshiba Audio... • Answered on Jan 07, 2022
Connecting my Klipsch screw terminal speakers to modern TV. My new TV only has a Sound Out plug. Is there a method to connect my old speakers to my new TV?
The manual is here https://tvna.compal-toshiba.com/us/wp-content/uploads/sites/2/2016/09/toshiba-43_49_55_65l621u_16-0706_web_v2_en_final_lr.pdf The connection for external speakers like you have is called analog audio output and it is shown with a little set of headphones next to it. The issue is the size of that jack. There are two basic sizes 3.5 mm and 2.5 mm . The manual does not say which one is on your television. If you have a set of headphones you can try that would let you know. Otherwise it is trial and error. What you need to do is get a cable that has that end on it and then make the connection to your speakers. Using the wires on the speakers you need to be able to tell what polarity they are and connect two of them to one of the wires in the cable that you found that fits the jack. These are the ground connection and on the cable the ground is usually a bare wire strand. Then the other two cables that are remaining, connect to each of the wires that are coming out of the connection to the television ( they should be colored) One goes to each for left and the other for right. You may want to solder them and make sure that you tape or insulate them against shorts.
9/8/2018 10:05:55 PM • Toshiba Audio... • Answered on Sep 08, 2018
Is there a preferred or compatible hand held microphone i can attach to my TOSHIBA LAPTOP TO RECORD A SONG SINGING.
They make usb mics. also there are ones that plug into your mic input jack, If you are really serious about your singing and want to invest a little more money you can get a AD/DA converter (analog to digital and digital to analog) here is a link. https://www.sweetwater.com/c796--AD_DA_Converters And every vocalist worth their salt needs as good a mic as they can afford. For $158.00 this mic is Durable with a wonderful sound and the price is affordable. This is a proven winner https://www.sweetwater.com/store/detail/Beta58a Then there is software for recording starting out with open source software recording software audacity Top of the line would be Pro-Tools by Avid recording software pro tools What ever kind of software you get there is a learning curve and most JR. Colleges offer classes and there are on line sources also like: Lynda https://www.lynda.com/signup and Groove3 https://www.groove3.com/about-us?gclid=CjwKCAiAvMPRBRBIEiwABuO6qV_9oXo5TopXi-SyrEVrQOFky5L8F55O5VCAVNH_oL3No0nVPGwAqBoCqQgQAvD_BwE There a lot of ways to go and if you start your journey by setting small goals and achieving them....Soon you'll have bigger fish to fry......Good Luck...........~~~~~~~~*BB
12/13/2017 8:13:04 PM • Toshiba Audio... • Answered on Dec 13, 2017
Toshiba REGZA 40" 40AV700 FULL HD LCD MULTISYSTEM TV FOR 110-220 VOLTS Logo
1 questions posted
Top Toshiba Audio Players & Recorders Experts
David Payne
David Payne
ADMIN Andrew
ADMIN Andrew
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Audio Players & Recorders
Most Popular Question
connecting klipsch screw terminal
  • Audio Players & Recorders
