20 Most Recent Logitech M-SBF96 Mouse Questions & Answers
Once i use the wheel
go to control panel > mouse> adjust mouse and scroll speed
10/4/2017 10:07:16 AM • Logitech M-SBF96... • Answered on Oct 04, 2017
0answers
HP M-BSF96
Be the first to answer 10/14/2013 3:01:03 AM • Logitech M-SBF96... • Posted on Oct 14, 2013Be the first to answer
Mabe drivers dont instaled.. Where
Below Link:
http://www.logitech.com/en-in/428/3358
Choose the Operating System and Download the Drivers!!!!!!
Good Luck!
9/20/2011 10:54:06 AM • Logitech M-SBF96... • Answered on Sep 20, 2011
M-Sbf96, need new driver
Full 32bit installation package - HERE Full 64bit installation package - HERE
Those links will work but if you'd rather do it manually go to there website reconix.png
next select the operating system you have, ie, Windows XP
Download from the link provided and install.
Hope this helps.
7/17/2011 1:42:05 PM • Logitech M-SBF96... • Answered on Jul 17, 2011
I can`t find my mouse
1.Open the llink : http://www.logitech.com
2.On top the 3rd option is SUPPORT. Click on Product Support under it.
3.Type M-SBF96 in the box under the 2nd option which is "Option 2:
Enter model number or product name"
and click on the symbol on right hand side.
4.Search Results will show "Optical Mouse PS/2
M/N: M-SBM96B,M-SBF96 "
5.Click on "Optical Mouse PS/2 "
6.On the right hand side under "Software Downloads" click on the download link .
7.Select the correct OS and download the driver.
For more information refer to the link mentioned below:
http://www.logitech.com/en-in/support-downloads/downloads/mice/devices/3358?WT.z_sp=Model
Waiting for your Feedback >>>>>>>Do Reply !!!!!!!!!!!!!!!!!!!!
3/11/2011 8:59:07 PM • Logitech M-SBF96... • Answered on Mar 11, 2011
Driver for M-SBF96 logitech mouse?
This mouse isn't supported by windows vista
7/9/2010 4:03:51 AM • Logitech M-SBF96... • Answered on Jul 09, 2010
Logitech mouse M-SBF96 Not Working Properly...
Hi, Please uninstall any logitech software version present on your OS (if available) - Then please proceed to clean boot. ( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 ) -> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if
possible rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for
new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software if available and/or plug the hardware when needed. -> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect
the device without the flag, unless there is some serious issue with the hardware/OS
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware
failures are covered by warranty terms
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
6/9/2010 11:20:36 AM • Logitech M-SBF96... • Answered on Jun 09, 2010
I have connected the mouse but the cursor is not
Is this a cordless? If so you may have something blocking the signal Between the mose and the driver unit. IE something solid between mouse and driver unit ,
3/12/2010 11:25:56 AM • Logitech M-SBF96... • Answered on Mar 12, 2010
Cursor jumps from place to place on screen.
When I have this problem I replace the mouse. You could try going into the control panel and going to mouse and keyboard icon. Try adjusting the settings put 99% It's just your mouse going back.
Good Luck
Proteus
11/19/2009 8:54:11 PM • Logitech M-SBF96... • Answered on Nov 19, 2009
Wireless keyboard and mouse not working
It seem that the keybd and mouse are not installed. Install the SW on the CD and then start using them. No internet connection is required.
8/24/2009 5:53:44 AM • Logitech M-SBF96... • Answered on Aug 24, 2009
Logitech mouse M-SBF96 Not Working Properly... I
just buy a new mouse. its not worth the trouble. they're only 20 bucks or even less.
7/14/2009 2:17:24 PM • Logitech M-SBF96... • Answered on Jul 14, 2009
Logitech mouse M-SBF96 wheel not working properly
Open the mouse. clean the roller.
3/2/2009 8:12:16 PM • Logitech M-SBF96... • Answered on Mar 02, 2009
2answers
This mouse is jumping around on me
if you are using the scrolling mouse, u can clean the balls of the mouse and use it.
After that i recomend, use the mouse pad for the smooth working of the mouse.
12/17/2008 5:18:08 AM • Logitech M-SBF96... • Answered on Dec 17, 2008
2answers
Logitech wireless combo mouse keyboard mk220 support through bluetooth
• Check the orientation of the batteries inside the keyboard and mouse, or replace the batteries. • Is the USB receiver securely plugged into a computer USB port? Try moving the USB receiver to a USB port closer to the keyboard and mouse. • If the USB receiver is plugged into a USB hub, try plugging it directly into your computer. • Remove any metal object between the receiver and the keyboard/mouse that may interfere with reception. Try using the mouse on a different surface. • Restart the computer. • If these suggestions don't work, download the Reconnection Utility from http://www.logitech.com/connect_utility.
2/28/2024 3:07:39 PM • Logitech... • Answered on Feb 28, 2024
Does the Logitech cordless mouse have data in it
Of course not. It is a simple I/O (input output) device. It stores no data. ..
2/3/2024 5:55:00 AM • Logitech... • Answered on Feb 03, 2024
Logitech M-SBF96 Mouse Logo
26 questions posted
Top Logitech Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Computers & Internet
Most Popular Question
driver m sbf96 logitech mouse
  • Computers & Internet
