since the self generated menu displays ok id say you don't have a monitor problem , could it be that maybe somehow it got switched over to maybe an "open" input port (example: hdmi-2) as this would explain things a bit , also when you tried the other tv did you use the same cables to connect it as the non working tv ? as that also would explain things
Check the Input Source: Make sure you have selected the correct input source on your TV for the device you are using. Use the remote control to cycle through the input options until you find the one connected to your video source.
Check Video Connections: Ensure that all video cables (such as HDMI, component, or composite cables) are securely connected between your TV and the device you are trying to watch content from. A loose or faulty cable connection could result in a loss of video signal.
Restart the TV and Video Source: Try restarting both your TV and the device you are trying to watch content from. Power off both devices, wait a few moments, and then power them back on. This can sometimes resolve temporary glitches or issues with the video signal.
Check for Software Updates: Make sure your TV's firmware is up-to-date. Sometimes software updates can resolve compatibility issues or bugs that may be affecting video playback. Check the settings menu on your TV for an option to update the firmware, or visit the manufacturer's website for instructions on how to do so.
Reset Video Settings: If you've made any changes to your TV's video settings, such as resolution or picture mode, try resetting them to their default values. This can sometimes resolve issues with video playback.
Try a Different Device: If possible, try connecting a different device (such as a DVD player or gaming console) to your TV to see if the issue persists. This can help determine whether the problem lies with the TV itself or with the original device you were using.
Contact Panasonic Support: If none of the above steps resolve the issue, it's possible there may be a hardware problem with your TV. In this case, you may need to contact Panasonic customer support for further assistance or to schedule a repair.
Check the Power Cord: Ensure that the power cord is securely plugged into both the TV and the power outlet. Make sure there are no visible signs of damage to the power cord or the plug.
Inspect the Power Outlet: Try plugging another electronic device (such as a lamp or a phone charger) into the same outlet to verify if it is functioning properly. If other devices work fine, then the issue is likely not with the power outlet.
Check for Tripped Circuit Breakers: Check your circuit breaker or fuse box to see if a circuit breaker has been tripped or a fuse blown. If so, reset the circuit breaker or replace the fuse and try plugging in your TV again.
Test with Different Power Source: If possible, try plugging your TV into a different power source altogether, such as a different room or building. This will help determine if the issue is specific to the power source you were previously using.
Contact Panasonic Support: If none of the above steps resolve the issue and your TV still does not power on, it's likely that there is a hardware problem with the TV itself. In this case, you may need to contact Panasonic customer support for further assistance or to arrange for repairs. Be sure to provide them with details of the troubleshooting steps you've already taken.
Turn off and unplug the projector.
Locate the lamp cover on the projector.
Remove the lamp cover.
Take out the old lamp.
Insert the new lamp.
Replace the lamp cover.
Reset the lamp hours:
Press the Enter button to display the "Option" menu.
Use the 5 or 6 button to select "Lamp Runtime".
Press and hold the Enter button for approximately 3 seconds.
The "Lamp Runtime" will change to "Time Reset [Power Off]".
Turn off the power and disconnect the power cord.
Finally, plug in and turn on the projector.
Remember to consult your projector's operating instructions manual for specific details and safety precautions. How to change Panasonic vx 400 xga projector lamp change or replace (youtube.com)
JustAnswerhttps://www.justanswer.com > Electronics Question
Jan 5, 2018 - The F60 error is an error that indicates a video processing board failure. Here are a few things that you can try (do one first then try number ...
1 answer · Top answer: Hi, I'm JA Engineer. Welcome to JustAnswer. I'm reviewing your question now and will post back ...
Reddit · r/VHS2 comments · 2 years ago
The VCR and DVD recorder won't eject/open on command either, so my guess is the capacitors on the power board are dead. Upvote
Question edited for clarity. I doubt your television id 58 FEET (58')
You don't give the model number or what you are trying to sign into? WiFi, Netflix, Cable, Parental Controls?
Here are some manuals
Panasonichttps://na.panasonic.com > ...
PDF
You need to subscribe to a cable TV service to enjoy viewing their programming. ... Check the input signal compatible with this TV. (see page 52 - 53). Page 55 ...
58 pages
Panasonichttps://help.panasonic.ca > viewing
PDF
• Has the battery run down? • Has the TV POWER button been turned On? • To operate external equipment of other manufacturers, register the remote control ...
35 pages
'riding'? Or do you mean 'writing'?
What does it say? Things like this are part of the settings menu, go to it and Exit out of it.
Or Google
make model manual
If you need to access your Panasonic television's menu and you don't have a remote, then your best option is to use the physical buttons on the television itself. There is a MENU button, often on the back of your Television.
