20 Most Recent Sharp HE CDDH950P Mini System Questions & Answers
From Netflix on your computer system for offline netflixlogin. This new function will be informed once we download.
Sharp HE... | Answered on Dec 19, 2017
Just talked to customer service at Sharp because I had same problem with my CD trays getting stuck and would not open even if they had cd's in them. He walked me through resetting the cd system. First have unit plugged in but in standby/off. Then press the open/close button, the stop button and the CD button all at one time(beside holding unit still to keep from sliding) till the display flashes CLEAR ALL and then let go and turn unit on and see if it solves your problem. It solved mine but I did write down instructions to make sure if it happens again I can use it again. Good luck, Helen
Sharp HE... | Answered on Feb 26, 2014
The surround sound system will work from the TV volume control!
Sharp Audio... | Answered on May 31, 2020
failing on off switch or wire short
Sharp Audio... | Answered on Apr 13, 2020
Check the power outlet for power.
Check the back for a screw-cap button fuse.
If that doesn't work, take it to a service centre.
**won't turn on. Contraction for 'will not'.
Sharp Audio... | Answered on Mar 20, 2020
Other than unpluggingfrom the mains (if haven't been tried) for an extended period of time (say overnight), there are no reset procedures applicable to this CD shelf system. The idea is to force the unit to revert back to factory defaults.
Almost always, a faulty speaker/connection would short out the output stages hence the 'PROTECT' error message. The only time this messge would be gone is when the built-in diagnostics no longer senses the fault, i.e. after it has been repaired.Sorry.
Sharp Audio... | Answered on Feb 01, 2020
refocus the lens. You are using twice the correct focal length, which is reversing the image.
Sharp Audio... | Answered on Jan 05, 2020
Hi I need help in turning of the timmer from my sharp stereo because it's not turning on and I don't have any remote for it what can I do
Sharp Audio... | Answered on Jan 04, 2020
can i show you a new feature of Google called SEARCH?
Sharp Audio... | Answered on Dec 04, 2019
Google (sharp)(SPC005)(manual) without parens OR contact Sharp directly to request it.
Sharp Audio... | Answered on Sep 21, 2019
Sharp HE CDDH950P Mini System Logo
6 questions posted
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Audio Players & Recorders
Most Popular Question
mini stereo cd dh950p when play radio
  • Audio Players & Recorders
