20 Most Recent
Avaya AWH-55 Professional Headset Questions & Answers
Hi, I have an issue
Try on another phone. I the headset then works fine the headset port on your phone is bad.
If there is still static on the new phone, the headset is bad....
AWH 55+
there should be a little round piece of plastic on a very thin cable. That goes on to the speaker, and plugs into the headset base/charger.
But, it does depend on which phone it is on. There is a possibility that you need an HL10 lifter.
People cannot hear me talk
Which headset is this, there is an A, B and C, button on the side, you may need to adjust that to set the headset for your phone.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
Yesterday
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
