20 Most Recent Logitech Cordless TrackMan Optical Trackball Questions & Answers
Disassemble M570 trackball
You don't need to disassemble it - Under the mouse is a hole, through which you can see the trackball. Insert your pinky (little finger), or the top (eraser) of a pencil, and gently push. The ball will pop right out, and you can clean it, and the three ball-bearings on which it rolls. I do this almost every day. (yes, my hands are clean, but normal oils gum up the ball-bearings.)
12/9/2017 3:20:27 PM • Logitech... • Answered on Dec 09, 2017
0answers
Mouse ball stops responding, or responds
Send it back for repair, there is no fixing the chip in a mouse. Sometimes they don't work after one day.
So it depends on how much you paid for it depends on if its work ending back.
This is a great mouse, I only use logitech.
It does have a 5yr warranty.
3/6/2014 3:38:12 PM • Logitech... • Answered on Mar 06, 2014
2answers
Cant unlock
Try removing the batteries, wait for a while ,reinsert batteries and reconnect to reciever. Let me know how it goes..
9/17/2013 7:46:47 AM • Logitech... • Answered on Sep 17, 2013
My mouse doesn't work with
Try bypassing the USB hub and plugging the receiver directly into a USB port on the computer. Sometimes devices won't recognize properly if they're going through a hub.
7/6/2013 11:02:36 PM • Logitech... • Answered on Jul 06, 2013
Trackball Quit working
I had one, loved it and it just stopped working one day. Logitech has a great warantee and they gladly replaced it witha brand new one. Well now the new one just stopped working today....I guess I have to call Logitech again......
3/31/2011 11:24:32 PM • Logitech... • Answered on Mar 31, 2011
A small chip/divot in the ball after it was
you can buy just the ball from the company, but first contact a computer repair shop and ask if they might have one lying around, these devices go bad and they may have some. To buy the ball from the company and pay shipping may be cost prohibitive and you might be better off just replacing the complete unit. one alternative if your handy. get some epoxy (from ACE hardware or etc). make up a small amount of the paste and fill the chip., when it drys (24 hours) sand it smooth and it should work again. the stuff is very hard and I have made repairs with it before on equipment that could not find replacement parts. good luck
3/11/2011 12:53:03 PM • Logitech... • Answered on Mar 11, 2011
Logitech Cordless Optical Trackman Radio
From what I found the frequency is 1 to 27.045 MHz
3/9/2011 2:38:06 AM • Logitech... • Answered on Mar 09, 2011
My left button acts like the right button at
Hi, it is very simple
>>> just click on start
>>> Choose Control Panel
>>> Click on Mouse
>>> There will be an option Button configuration just unchecked and apply and then ok
Your problem has been resolved my friend.
Good Luck
2/3/2011 4:30:24 AM • Logitech... • Answered on Feb 03, 2011
After months of good work my mouse stopped
Has any new piece of hardware been put in between the trackball and the receiver? Electro-magnetic fields can cause interference. I had a similar problem once - didn't even unplug the receiver, just moved it behind the monitor. It was a big clunky CRT screen and created a huge EM field - huge enough to cause interference with the trackball.
12/21/2010 8:48:48 AM • Logitech... • Answered on Dec 21, 2010
Looking for the Manual supplied on the installation disk.
Please find below the link for the user manual: http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/10541
Thanks and have a great day !
J -
11/12/2010 10:12:05 AM • Logitech... • Answered on Nov 12, 2010
TrackMan Wheel Trackball Spring - where does it go.
it's not really a spring -- it's just a twisted piece of wire. actually, it's what makes your little scroll wheel click when you turn it. place the scrool wheel in the little plastic bracket that holds it with the longest piece of axel (hollow side of wheel) in. then TURN THE BRACKET OVER. the wire goes on the BOTTOM, which is quite counterintuitive. you'll see how it goes -- the smallest end of the wire goes INSIDE the scroll wheel and the kinda squared end of the wire goes into a little hole in the bracket. you'll understand when you look closely at it. once the wire is installed, hold it in place when you turn the bracket/ball/wire assembly over. fit the legs on the bracket into the groves on the base of the trackball -- that's the side where the ball sits and the circuit board is. make sure the scroll wheel passes through the trackball cover when putting it all back together. VOILA! problem solved.
10/31/2010 3:47:13 PM • Logitech... • Answered on Oct 31, 2010
Having problems installing trackman optical
Go in to windows update webpage , do all the update that you can do , particularly driver update, then try to instal the driver again for the mouse.
txexixs
9/11/2010 7:33:26 PM • Logitech... • Answered on Sep 11, 2010
3answers
Reassemble T-RA 18
8/17/2010 2:19:14 AM • Logitech... • Answered on Aug 17, 2010
Logitech Cordless TrackMan Optical Trackball Logo
57 questions posted
Top Logitech Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Computers & Internet
Most Popular Question
small chip divot in ball after
  • Computers & Internet
