20 Most Recent
Pyle 10 Channel 800 Watts Powered Stereo Mixer W/dual 7-band Graphic Equalizer Questions & Answers
Pyle PBMSPG190 can't scan fm stations
If you're having trouble scanning FM radio stations on your Pyle PBMSPG190, there are a few things you can try:
- Check your antenna: Make sure your FM antenna is properly connected to your radio and is positioned in a location with good reception. If your antenna is damaged, you may need to replace it.
- Check the FM frequency range: Make sure that the FM frequency range of your radio is set correctly for your location. In some cases, FM frequencies may differ depending on your country or region.
- Check for interference: Electronic devices such as smartphones, tablets, or other nearby radios may cause interference with your radio's ability to pick up FM stations. Try turning off nearby electronics or moving your radio to a different location to see if this improves reception.
- Manually tune to specific frequencies: If the automatic scan is not working, try manually tuning your radio to specific FM frequencies to see if you can pick up any stations.
If none of these steps work, it's possible that there may be a problem with the radio's internal components. In that case, you may want to contact Pyle customer support for further assistance.
My pyle boombox turned on but no sound in any mode
If your Pyle boombox has turned on but there is no sound in any mode, it could be caused by a problem with the speakers, the audio output, or a software issue. Here are a few steps you can try to troubleshoot the issue:
- Check the speakers and ensure they are securely connected and not damaged. Make sure the volume is turned up and the audio source is set to the correct input.
- Check the audio output and ensure it is not set to the wrong output. Make sure the audio output is set to speakers and not headphones or Bluetooth.
- Check the audio source and ensure it is properly connected and working. Make sure the audio source such as a USB, SD card, or Bluetooth is properly connected and that the sound is not muted.
- Try resetting the boombox by unplugging it for a few minutes and then plugging it back in. This will force the boombox to restart and may resolve the issue.
- If the above steps do not resolve the issue, it may be necessary to have the boombox serviced by a professional technician.
My Pyle Pt694bt is in protect mode how do I reset it or where do I get it repaired?
you can use the instructions in the product manual to help factory reset your device. Otherwise, you can take it to a store like Geeksquad/Bestbuy in order to get the device factory reset on your behalf. But you might want to call ahead first to ensure that location has access to the manual in order to perform the factory reset.
Thank you.
11/17/2022 10:51:49 PM •
Pyle Audio...
Answered
on Nov 17, 2022
How do I change region code on Pyle pd1000a? Need region 1 and all I get is not formatted to play in this region error message. Don't know what region this thing is programmed to but need to change. P
When a DVD disc is created, it is encoded with a "Region number." The disc will only play on DVD players with the same Region number - for instance, a Region 3 disc won't play on a Region 1 player.
Region 1: U.S. and U.S. Territories, Canada
Region 2: Japan, Western Europe, Middle East, South Africa
Region 3: South Korea, Hong Kong, Taiwan, Southeast and East Asia Region 4: New Zealand, Australia, Pacific Islands, Mexico, Central/
South America
Region 5: Russia and the former Soviet Union, Africa, Indian
subcontinent, North Korea Region 6: China
The only way to get around the region codes, is to rip a DVD to your computer and remove the region code. Then burn the DVD to a DVD R. There are programs around on the net, but I'm not sure it is legal in all countries.
Google for the programs.
A DVD player sometimes allows you to change the region code once. But it not even would allow you to switch back after you changed it once.
I have the pyle PDIC83T speakers and how do I know what setting to put each speaker on, I will have 4 in one big room?
Hello Patt, the configuration of the speakers will depend on their height, surface to cover, and distance between them, as well as the amplifier to use
As an initial test, put the selector switch of each speaker for the 10-watt position and test the result
Depending on this test, you will have to raise or lower the power, to achieve the best coverage
I hope you serve the suggestion
Greetings Franco Dosil
Hola Patt, la configuracion de los parlantes dependera de su altura, superficie a cubrir, y distancia entre ellos, como asi tambien el amplificador a usar
Como prueba inicial, ponga la llave selectora de cada parlante para la posicion de 10 watts y pruebe el resultado
Dependiendo de esta prueba, tendra que subir o bajar la potencia, para lograr la mejor cobertura
Espero le sirva la sugerencia
Saludos Franco Dosil
