20 Most Recent Mustek 7-Inch Digital Photo Frame Questions & Answers
Read the instructions on how to turn on the Slideshow feature.
Mustek 7-Inch... | Answered on Dec 22, 2014
Music has a positive effect on the concentration level of the listeners. It is also found to improve one’s memory. Research has found that the silence between two musical notes triggers the brain cells and neurons, which are responsible for the development of sharp memory. Flute music, and instruments like santoor and sarod are recommended for the enhancement of concentration and memory. Strong beats cause the brain waves to resonate in synch with the beat bringing about higher levels of concentration and alertness.
Music plays a vital role in enhancing creativity. Music has a positive impact on the right side of the brain. Music triggers the brain center, which deal with the development of creativity. Certain ragas are known to activate all the chakras of the listener’s body, thus benefiting him/her in the performance of other creative tasks.
Music is found to give students the capacity to trust themselves. It provides them with an internal discipline. Rhythm is known to help the students learn math. Music stimulates the brain centers that deal with thinking, analyzing and planning, thus enhancing one’s organizational skills.
Music helps secrete endorphins that help in speeding the process of healing. It acts as an effective distraction from pain and suffering. While diverting one's mind away from pain, it also helps bring about certain chemical processes in the brain that aid healing. After undergoing surgery, patients may be advised to undergo a music therapy. Listening to melodious, comforting music is sure to have a positive effect on the physical and mental well-being of patients.
Mustek Audio... | Answered on Dec 28, 2018
Did you have a specific model in mind?
Maybe run it by the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usersmanualguide.com
Mustek Audio... | Answered on Mar 07, 2011
Hello. I´, from Portugal and I have the same problem. I the control unit isn´t working. I tryed to solve the problem but no one could help me.
Mustek Audio... | Answered on Aug 13, 2010
It is radio controlled and sets itself.
Audio Players &... | Answered Yesterday
This is a very common issue. Unplug the mini power jack the thing with the cord. Look inside the chargers hole on the jam box and then take a knife to gently bend the tab back towards the middle or even lower. Be careful when you are re plugging into the power into the socket. The socket tab and the mini plug must meet .
Audio Players &... | Answered 3 days ago
The AUX connection is what the Line In connection used to be called and generally has a medium impedance and a sensitivity of upwards of 800 mv, often 1 to 1.5 volts, being the typical output of a tuner or tape deck.
Details of this is usually found in the user manual - good matching is repaid in better quality sound and reduced interference.
Press the buttons of your mystery appliance in the correct order.
OR
You could Google
make model manual
Audio Players &... | Answered on Aug 01, 2020
The DVD and *and* the DVD player both have a region code embedded in each. A map of the regions used appears below:
Regions 0, 7, 8 & 9 do not appear as they represent "No Region Coding" "Unused" "Cruise Lines" and "Region Free" respectively.
A DVD player will only play a matching region code DVD, or the player OR DVD have one (or more) 0, 7, 8, or 9 region codes imbedded. You'll not be able to change the DVD code, but you *might* be able to change the region code of your player. Computer DVD players can sometimes be flashed to a new region more readily than the entertainment system DVD players, but it relies solely on the manufacturer and model of the player. Some require file be downloaded and run, while others require a DVD or CD be created and played with a specific file saved on it. Here's a link to results that discuss how to change the region code for DVD players. You'll need to know at the very least the manufacturer and model number of you player to begin.
I hope this helps and good luck! If you found this helpful, please rate my reply 4 "thumbs up". Thanks!
Audio Players &... | Answered on Jul 30, 2020
Press and hold the MFB buttons for about 5 seconds to turn them off. When both earbuds are paired with your cellphone, press and hold the MFB button on either left or right earbud, the other earbuds should turn off at then at the same time.
Audio Players &... | Answered on Jul 29, 2020
The speakers may be burned out.
Audio Players &... | Answered on Jul 27, 2020
The manual has the complete process how to set time.
Audio Players &... | Answered on Jul 22, 2020
Mustek 7-Inch Digital Photo Frame Logo
1 questions posted
Top Mustek Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Mustek Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Mustek Audio Players & Recorders
Most Popular Question
make run continusly
  • Audio Players & Recorders
