20 Most Recent Mustek 7" Pf-a722bm 400x234 Digital Photo Frame & Mp3 Player black Questions & Answers
Music has a positive effect on the concentration level of the listeners. It is also found to improve one’s memory. Research has found that the silence between two musical notes triggers the brain cells and neurons, which are responsible for the development of sharp memory. Flute music, and instruments like santoor and sarod are recommended for the enhancement of concentration and memory. Strong beats cause the brain waves to resonate in synch with the beat bringing about higher levels of concentration and alertness.
Music plays a vital role in enhancing creativity. Music has a positive impact on the right side of the brain. Music triggers the brain center, which deal with the development of creativity. Certain ragas are known to activate all the chakras of the listener’s body, thus benefiting him/her in the performance of other creative tasks.
Music is found to give students the capacity to trust themselves. It provides them with an internal discipline. Rhythm is known to help the students learn math. Music stimulates the brain centers that deal with thinking, analyzing and planning, thus enhancing one’s organizational skills.
Music helps secrete endorphins that help in speeding the process of healing. It acts as an effective distraction from pain and suffering. While diverting one's mind away from pain, it also helps bring about certain chemical processes in the brain that aid healing. After undergoing surgery, patients may be advised to undergo a music therapy. Listening to melodious, comforting music is sure to have a positive effect on the physical and mental well-being of patients.
Mustek Audio... | Answered on Dec 28, 2018
Did you have a specific model in mind?
Maybe run it by the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usersmanualguide.com
Mustek Audio... | Answered on Mar 07, 2011
Hello. I´, from Portugal and I have the same problem. I the control unit isn´t working. I tryed to solve the problem but no one could help me.
Mustek Audio... | Answered on Aug 13, 2010
Is this one of the units that has a ribbon cable ( looks alot like an IDE hard drive cable) that connects all the components together? It also has a squre plastic fan that protrudes slightly from the rear (by about a 16th of an inch)? If so, it's the power module which consists of 2 boards (along the fan housing). You can probably find replacements for about $70, but I wouldn't bother. They quit making new replacements several years ago and any board you get now is just a pull from old stck units.... and they fail about 2 minutes after you put them in. Pioneer knows this but still sells the defective parts.
Audio Players &... | Answered Yesterday
you need to get into the box, and sort all 100 of the cd's out yes all of them..
to this i mean make sure they are in there tray's properly,second make sure the tray's are not "racked",ie that they have not slid out of there small holder's..
now once u have the mean's open the juke box..
find the black switch, pull it out to engage service mode<,
now u go to work on the cd's, then you will hit "h" 0-0 "h"
this should clear your error 73 code ,as long as all the cd's are in there proper place's
press switch back in, you are then back to normal play
at the point of closing the door you might need to power cycle the juke box
Audio Players &... | Answered 3 days ago
Connect the AUDIO OUT ports on your DVD player to the audio in ports on your TV with the regular or standard audio cables (red and white jacks). Connect the AUDIO OUT ports on your TV to your speakers using a standard audio cable, or a digital audio Optical cable.
Audio Players &... | Answered on Aug 09, 2020
200 watts is the output, home use or commercial? not a good amp to run at its max as it has a low reserve headroom. for home use 100 watts rms is more than enough.
It is radio controlled and sets itself.
Audio Players &... | Answered on Aug 04, 2020
This is a very common issue. Unplug the mini power jack the thing with the cord. Look inside the chargers hole on the jam box and then take a knife to gently bend the tab back towards the middle or even lower. Be careful when you are re plugging into the power into the socket. The socket tab and the mini plug must meet .
Audio Players &... | Answered on Aug 03, 2020
The AUX connection is what the Line In connection used to be called and generally has a medium impedance and a sensitivity of upwards of 800 mv, often 1 to 1.5 volts, being the typical output of a tuner or tape deck.
Details of this is usually found in the user manual - good matching is repaid in better quality sound and reduced interference.
Audio Players &... | Answered on Aug 02, 2020
Press the buttons of your mystery appliance in the correct order.
OR
You could Google
make model manual
Audio Players &... | Answered on Aug 01, 2020
Mustek 7" Pf-a722bm 400x234 Digital Photo Frame & Mp3 Player black Logo
1 questions posted
Top Mustek Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Mustek Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Mustek Audio Players & Recorders
Most Popular Question
ac power jack came loose from board
  • Audio Players & Recorders
