20 Most Recent Moyer Diebel 401HT Dishwasher Questions & Answers
A service man might have a used one kicking around. Or buy new.
Moyer Diebel... | Answered on Feb 13, 2014
The pump and motor comes as one unit. Motor does not come seperate. Pump parts can be sold seperately
Best way is to contact a chemical supply company and have them do it. The delime product should not be mixed with chlorine.
could be a number of problems. Checking with an ohm meter would determine the problem. Could be the booster high limit thermostat, a burnt wire, booster thermostat, or a heater element.
Moyer Diebel... | Answered on Jan 25, 2012
I'm too late for you but others could be helped. With the power off' make sure the timing cams are set to the beginning of cycle, Then push the cams with a finger untill the fill cam switch just activates. Then put the power on,close and latch door and water should enter the booster. You might have to do this 2 times to get water at correct level inside machine. When the cycle lite goes off check for water inside machine. If water level is too high, then take some water out with a cup.
thats ok, just reset, if it happens again replace. could be that the booster thermostat didnt shut off the one time. Keep an eye on the temperature guage to see that the temperature is not fluctuating too much over 85c
Moyer Diebel... | Answered on Jan 11, 2012
If the temperature was ok before, and no one has adjusted the thermostat, then that is an indication of a thermostat that needs to be replaced.
yes you can. but nothing will be sanitized
If the machine still has a detergent pump, then the hose could still be taped to the back of the machine, half way up on the outside. It would have a label on it that says detergent. If the pump is missing then use a commercial grade powder detergent if your health inspector allows it. You would have to put in approx. 1 tablespoonfull each load.
possibly the temperature high limit switch needs resetting, by pushing the centre button in with your finger. Make sure power is off first.
possibly the thermostat needs replacing
Moyer Diebel... | Answered on Jan 10, 2012
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Moyer Diebel... | Answered on Apr 22, 2011
The thermostat for the final rinse booster might be set too high causing the water to boil in booster tank. Water will then spray even when cycle is complete. Turn the thermostat down to 180f or 82c to comply with health regulation. If problem continues replace booster tank thermostat. Or if you have hard water pull thermostat and clean
Moyer Diebel... | Answered on May 10, 2019
Dishwashers Logo
19 questions posted
Top Moyer Diebel Dishwashers Experts
GPEC
Level 1 Expert
Phillip Cushnie
Phillip Cushnie
Level 1 Expert
Tom Chichester
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Moyer Diebel Dishwashers
Most Popular Question
dishwasher works 15 seconds
  • Dishwashers
