20 Most Recent Integra Dtr-7.1 Av Receiver Surround Sound Home Digital Theater Receiver Remote Questions & Answers
If you have a volt meter you may try and repair it yourself. First however disconnect the speakers and see if the set still goes into protect. If so you may have shorted output and drive transistors. There will be open resistors near them as well. You can compare the bad channel with a nearby working channel since normally only channel shorts out at a time. Always replace outputs in pairs since they in push pull configuration .
Integra Dtr-7.1... | Answered on Dec 15, 2015
http://www.integrahometheater.com/faqs.php Check the connections and try a master reset?
Perform a master reset. To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode.
Integra Audio... | Answered on Jul 03, 2018
You have a defective processor pcb assembly and it must be changed.
Integra Audio... | Answered on Feb 19, 2015
You will have bad output transistors, a $124 to 150 repair in shop service
Integra Dtr-7.1 Av Receiver Surround Sound Home Digital Theater Receiver Remote Logo
2 questions posted
Top Integra Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Larry Stiles
Larry Stiles
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Integra Audio Players & Recorders
Most Popular Question
dtr 7 1 integra receiver goes into
  • Audio Players & Recorders
