20 Most Recent Dell AY410 Multimedia Speaker System Questions & Answers
Need a power adapter for a dell ay410 speaker system. where can i get one
You should be able to use a generic one which are widely available. All you have to do is make sure the connector is the same type and size and the input voltage matches. There should be a sticker near the power input socket with the correct voltage
2/18/2015 4:36:20 PM • Dell AY410... • Answered on Feb 18, 2015
0answers
How do i open my speakers, there's no screws
Click here to follow these steps https://mybestspeakers.com/how-to-take-apart-speakers-with-no-screws/
12/15/2021 6:41:17 AM • Dell Audio... • Answered on Dec 15, 2021
2answers
I have Dell speakers, hp tower, I can't get sound out of speakers. Do I plug both the usb plug & speaker plug into tower?
If there is no separate power supply the usb plug must be used in order to provide power for the speakers, but whether the analogue cable must be plugged in or not will depend on the internal construction and specification of the speakers. I suggest you initially use the usb and if there is no sound and no on-screen instructions, plug in the analogue line. If there is a separate power supply the speakers are probably and either/or design.
12/4/2018 4:19:38 AM • Dell Audio... • Answered on Dec 04, 2018
2answers
My Dell P32E just all of a sudden started having static and dragging when playing music and also some static when not playing music. This is my lifeline! How do I fix it?
what is 'dragging'? most likely dirty contact on the plug from computer to the speakers.
10/3/2018 12:02:00 AM • Dell Audio... • Answered on Oct 03, 2018
Hello there..I've got a Dell
Windows has a troubleshooter for the audio system in most computers. Get the "fix" here: https://support.microsoft.com/en-us/help/4026994/windows-fix-sound-problems Good luck!
1/14/2018 6:06:10 AM • Dell Audio... • Answered on Jan 14, 2018
My applications last only as long as I leave my computer on. How can I make them stick?
Is there a battery back up somewhere on your computer? It could have failed. Or at least something connected with it. It could be an electronic fault. Bad capacitors etc. I assume they have ruled out a virus?
11/24/2017 8:07:05 PM • Dell Audio... • Answered on Nov 24, 2017
Background noise recording with dell
Get a wired lapel microphone and plug it into the microphone input on your Dell. The onboard mic is designed to record all ambient sounds. You want a different product to get the result you're looking for.
5/20/2017 2:35:03 AM • Dell Audio... • Answered on May 20, 2017
Altec Lansing ADA 745 speakers.
you need an amplifier
5/6/2017 10:26:40 AM • Dell Audio... • Answered on May 06, 2017
How to take apart a dell mms 5650 subwoofer
funny thing about speakers is that they need an enclosure to work properly in the unit has a back and the car has a door skin or other enclosure to work in
2/5/2017 12:45:30 AM • Dell Audio... • Answered on Feb 05, 2017
Setup Altec Lansing BX1220 speakers usb-powered...green 3.5 in back with usb next to it. I have a windows 10 free upgrade on a rebuild Dell Optiplex 755 vista desktop.
Forget the upgrade to windows 10, Dell doesn't recommend you do this as it disables some programs. I have the same computer.
9/23/2016 7:15:53 PM • Dell Audio... • Answered on Sep 23, 2016
Dell a525 speakers. One side is louder than the other. What can I do to fix this problem?
adjust the balance knob to center position
5/30/2016 5:47:12 AM • Dell Audio... • Answered on May 30, 2016
How do I find driver for my speakers. Disc not available. They stopped working after MS update.
My daughter had the same trouble with her Dell computer. The guy who was reloading Windows found the additional drivers on the Dell website. The Dell recovery disc supplied with a new machine already contain those drivers.
2/23/2016 10:30:26 PM • Dell Audio... • Answered on Feb 23, 2016
How can I fix the sound on my Windows 7 computer
Try plugging a pair of headphones or earbuds or a different pair of known-working speakers (in places of the current speakers) - if you get sound with the "replacements", then there's a problem with the "current" speakers; otherwise, the problem is the sound on the unit. Alternatively, plug the "current" speakers into a different (preferably, known-working) unit. If there's still no sound, then there's a problem with the speakers; otherwise, the problem is the sound on the original unit.
1/5/2016 1:13:42 AM • Dell Audio... • Answered on Jan 05, 2016
I have any Silex 824 Dell computer 2.1 subwoofer system the wires or cut how can I repair them properly
Joseph Nucifora, Unfortunately, Dell does not have any wiring diagrams for speakers or sub-woofers. They would replace them if they are broken and are under warranty. Thank You, Dell-Jesse L Dell Social Media and Communities
10/30/2015 5:44:22 PM • Dell Audio... • Answered on Oct 30, 2015
I have this problem. When I attach the mp3 player to my lap top with USB cable it does not recognize it. What do I have to do?
have this problem When attach the mp3 player to my lap top with USB cable... Did it recognize previously? If you are using it first time and it's not recognized, you should return it. Else, you should test your player on another computer. If doesn't show up as Removable Disk, your mp3 player passed out. You can't do anythig.
6/24/2015 3:20:28 PM • Dell Audio... • Answered on Jun 24, 2015
How do I plug the 3 wires from speakers into Dell XSP 8700?
Anonymous, Below are the jacks for the sound card. Hopefully, it will help you get your speakers connected to the correct jack. Realtek ALC3861 7.1 integrated audio Gray = Middle surround out Black = Rear surround out Orange = Subwoofer and center out Pink = Microphone Green = Stereo out, Front Speakers, Headphones Blue = Stereo in 25627675-cmq4uuvgx1xlr2vsmpalf0ir-5-0.jpg Thank You, Dell-Jesse L Dell Social Media and Communities
4/6/2015 1:56:31 PM • Dell Audio... • Answered on Apr 06, 2015
Dell AY410 Multimedia Speaker System Logo
3 questions posted
Top Dell Audio Players & Recorders Experts
Ekse
Mandeep  Singh
Mandeep Singh
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Audio Players & Recorders
Most Popular Question
need power adapter dell ay410 speaker
  • Audio Players & Recorders
